Had 350awkw whilst on stock bottom end, when we pulled it down (due to oil pump failure) it was still in perfect condition
Don't doubt that you could make over 400kw, but I'd imagine you'd be running some risk
Edited by Morgs
This is a question that often belongs in the 'say what I want to hear' / ' I can't afford to run the powerful car' category
If you want to rely on the old stock engine in the old stock car then the limit is really around/just above where the stock turbos run out of puff or the size of your bank balance. You see, if it matters that the motor breaks then you have the lower limit of power. Alternatively the question is answered; power level = 'lets see if it breaks' when you have the finance not to care.
Someone I know ran a 10 with an unopened old stocker. If you have another motor waiting and own a car trailer then you have nothing to worry about.
The ideal is to look at 300rwkw or under and do as much as you can to make that power with the least strain on the old motor.
Further up the power level is a list of stock bits that will also fail according to application.
Edited by rev210
You have a R32 GTR.
Motor is what, 16 years old now at a minimum.
What MAX power can you make? Probably over 500rwkw for one dyno run.
Reliably however, 300-330rwkw would be a pretty good limit to set given the age of the motor
Other than that, its the age old 'how long is a piece of string'. Some fail at less, some more.
If you cant afford the rebuild, then dont chase power (rebuild = min $12,000 round trip including turbos etc etc)
i would say adding another 100 would be safe. i am conservative with rb26 cos i think with my pockets.
i have seen them with around 400 but its not an everyday car its driven once a month maybe. at 300alkw u have a very zippy car on the street and running very little risk.
With the stock turbos you should be able to make about 240rwkw without blowing the ceramic turbine wheels to bits.
Or go for some GT/SS's and provided you have computer/injectors/fuel pump you could be looking at 300-320rwkw on a reasonably safe 1.2bar.
With 1 bar boost on stock turbos, i made 265rwkw.
How long the stock bottom will last depends on how well the engine was maintained.
similar here...made 287KW at SAU dyno comp with completely stock long engine and turbo's on 1 bar
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
    • This is a pump I have used in the past; no oil ever leaks or gets past the regulator plug.I was trying to understand what caused Nissan to not only mention it in their manuals but to also state it's a replacement part yet the part cannot be found on my pump or on any new pumps and there doesn't seem to have ever been a replacement part#.  First time I've noticed something strange like this from NIssan.
    • yeah I have brown peeking out from in between some metal sheets close to the hood hinges. Strut towers look fine, even around the edges. some images https://imgur.com/a/brGt3Tu the one that looks the worst is the panel(s) going away right near the firewall on the passenger side, from underneath. Driver side does not look that bad.
