OK yesterday went out drifting and came off the track to find out there is oil coming from my pod filter and lots of smoke when on boost.
sounds to me that is blow-by, "worn rings" but i was not sure cause there is no smoke if you dont hit boost.
I was able to drive home and did not touch boost once and had no smoke and no oil leak out.
The car has not lost any power still going as hard , its idling fine and running smoothly.
Any suggestions what it could be?
yeah i reckon it would be a oil turbo seal if its not that it will be a ring on one of ya pistons, cause ya car would still idle and run fine till ya hit boost under load and it will do it as well cause mine was filling my catch can up all the time when i held it on boost under load most of the time going up hills
