Hey guys,
was just wondering if its possible to use this:
http://cgi.ebay.com.au/R32-Skyline-RB20DET...1QQcmdZViewItem
as a possible upgrade for my R33 as opposed to doing something like a Power FC. I kno the R33 chips cannot be flashed like the R32 ones, thats why i was thinking of exploring this option.
Edited by YDUTRY4
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/
no but there is a rumor that Tilbrook auto and dyno may/can re-map standard r33 computers so give him a call 8261 8619
:P Holy shiezzer, for real? Im calling rite now, if thats a yes then FMIC & this are my next steps of tuning!
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3894430
Jeff from The Speed Lab can tune an R33 ECU - but it just requires a modification to the ECU. From what I understand the R33 ECU requires some components to be changed (adding of a daughterboard I believe) therefore will add a couple of hundred on top of the normal tune cost...
so if it's $600 for an R32 tune, expect about $800 or so for the R33 tune :P
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3894636
Well actually YES
Ring Jeff, He can Reflash R32 and Z32 ECUs and remap them for use in R33's. It's cheaper than remapping the R33 one as you don't have to buy the daughter board.
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3895466
Although you CAN use the R32 ECU, why would you skimp on ~$200 to remove extra driveability?
I just don't see the point in doing it half assed.. you say you wont notice the loss of mid-range, but why lose it at all? :D
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3897440
I spoke to Jeff around lunch time and he reackons that yes you do loose a little bit but its not noticeable.....and the power gains is pretty impressive.....so i am going with that option...dont worry i will still have my stock ecu sitting at home just in case
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3898159
yeah thanks simon.....thats the same answer i got from Jeff.....i am going to get Jeff to do a dyno run on shoot out as the car is and then one after the tune and then give me the 2 print outs......
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3900420
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
