i have a s15 with a big setup, rb30/26 1100 hp turbo, and its still manual.... rb25 box, strengthened....
i have also added a r32 gtr complete rear end to the car,
i have hsd coilovers and now i would like to set it up to get off the line hard, like gt autosound or devilsh.....
what would i need to do, do these cars still run irs or have they been converted to some type of 4 ling system, id rather not convert anything as it is still a street driven car ocasonally..
regards
denis
remove the coilovers and go back to the stock suspension.
If you want a compliant drag like rearend setup, make the suspension as loose as possible. 90/10 shocks in the front. 50/50 in the rear. stock springs, shouldn't be a problem.
Riding the clutch is what learner drivers do to hold the car on a slight hill because they cannot use the handbrake,accel and clutch at the same time.
To slip the clutch is engage the clutch gradually but quickly. This is so the car has some momentum before stepping off the clutch completely. Allows you to get off the line without errupting into wheelspin.
It takes practise to get it right,too much clutch and you will either bog down or spin the wheels. Not enough and your clutch plate will just grind on the flywheel,resulting in a slow launch and a flywheel with heat spots in it.
1-2 seconds of clutch slip is what you want to aim for.Depending on your setup.
In the most basic terms:
people are saying to use soft/stock rear suspension because of weight shift. If the back is soft, as you launch, the weight shifts backward onto the rear wheels. More weight, more traction, more grip, better launch.
If you have 12kg rear springs of a circuit car, then there is no large rearward weight shift, less traction, less grip, wheelspin hell.
think about it.
With that kind of power the stock suspension probably will not cope...and if its too soft its gonna squat on its arse and the camber will open right up hampering traction even more...
that's why with a drag setup you would run some positive camber at the rear
In regard to setting up a 2wd drag Skyline, I posted this recently (that's why the Search button is so handly) and it all applies to an S15;
You want no more then 3 kg/mm rear springs, around 2.5 kg/, is better. You want rear shocks with very little low frequency bump valving but a large amount of low frequency rebound damping. If the shocks are a decent brand then you can leave the high frequency valving alone. The soft spring rate allows the rear to squat and absorb the torque hit, the large amount of low frequency rebound damping holds the rear down for maximum weight transfer onto the rear tyres. The problem is you get a lot of dynamic negative camber when you get enough squat, so you need to set the static rear camber slightly positive (around 0.5 deggres). A rear subframe alignment kit installed in the "Maximum Traction" positions is also a must.
Around 3.5 to 4.0 kg/mm front springs are OK (hardly "hard"). You want front shocks with a large amount of low frequency bump valving but with very little low frequency rebound damping. Similarly to the rear, if the shocks are a decent brand then you can leave the high frequency valving alone. The limited amount of low frequency rebound damping allows the front suspension to extend therebye reducing the weight over the front and hence more effective weight transfer to the rear. The reasonable front spring rate helps to hold the front tyres onto the track, you may need to steer at some point. The front suspension geometry is pretty much irrelevant, just make sure the wheels are pointed straight ahead (zero toe) so they don't provide too much drag.
In a general sense the average Japanese aftermarket coil over kits are not suitable for drag racing and the standard suspension is better. But (there is always a "but") the problem with the rear standard shocks is that they don't have anywhere near enough rebound damping. That's when they are new, let alone 15 or so years old. So you get bad axle tramp, the kind that breaks drive shafts. The more power the car has, the worse this problem becomes. In a standard'ish Skyline (boost up, FMIC, exhaust etc) you might just get away with it (standard shocks) on street tyres. But drag radials or slicks and decent power don't mix well with poor rebound control. You will spend more money/time replacing drive shafts than you will spending the extra on buying the right shock spring combo.
I did this type of set up for BU5TER and his R33GTST which did a 1.5 for 60' first time out.
Cheers
Gary
serious? i got 2.1 60 ft time with coil overs so with stock suspension i can do better?
My car managed 2.0 with coil overs lol!
the secret?
5psi in the tires...
Nice smokey burnout.
4000rpm drop
:D
(my mate drove it this run)
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
