As the topic states, my GTR is for sale, I'm currently settling on a house and have too much money tied up in it.
1995 Nissan Skyline GTR Vspec - $28,000
Make: Nissan
Model: Skyline GTR Vspec
Milage: 56,000
Colour: White
Currently registered? Yes, October 08
Price: $28,000
Brakes:
- Project Mu SCR slotted rotors
- New Ferodo DS2500 brake pads
- Nismo Braided Brake lines
- Cusco Master Cylinder stopper
Suspension:
- Whiteline camber, castor, and subframe alignments kits
- Whiteline front and rear adjustable sway bars
- Whiteline bushing kit
- BuddyClub Racing Spec coilovers, height and damper adjustable - fitted approx 1 month ago
Engine:
- Apexi pod filters
- Greddy Carbon Fiber diversion plate
- 21 row oil cooler & filter relocation
- Nismo Oil Separator
- Mines ECU
- Kakimoto Cat Back Racing Muffler
- UAS Sport Clutch
Other:
- Driver & Passenger 4 point harness's fitted
- Nismo White faced gages
- Nismo gear knob
- Team Raceworx Atessa controller
- Fire extinguisher fitted
- Pioneer DEH P6850MP Head Unit with IPOD adapter & Pioneer Speakers
- HKS 6 point bolt-in roll cage (engineerable), and I've retained the entire interior in the car.
- Foglights (easily removable)
- Alarm / Immobilizer
- Bridgestone Adrenalins fitted
This car is awesome, has absolutely 0 problems and is still in showroom condition.
More parts are available with the car as well:
- Aftermarket dump pipes and front pipe
- Standard ECU
- Standard Swaybars
- Standard GTR coilovers
PM me for a phone number.
Pictures:
https://www.sau.com.au/forums/topic/220902-1995-r33-gtr-vspec/
Hey guys,
I was the prefious owner of this car and I can tell you that as of Januray this car was in pristine condition. If you are looking for a very solid R33 GTR this would be a good place to start.
Hi, l was wondering if you're willing to swap for a 1995 R33 GTS4? + Cash on top obviously, can pay up to 10-13k cash on top for the vehicle.
Where are you located in Sydney
http://www.skylinesaustralia.com/forums/19...amp;hl=r33+gts4
Heres the link.
Hey guys,
Thanks Tim, it is an absolutely great car and I've maintained it in the same condition as you did, if I could afford both the house and the GTR it wouldn't be up for sale.
Heres the link.
Nah sorry mate, only selling it because the money is needed elsewhere!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
