hey
i PM'd sliding performance about buying a clutch.
i told him i have a r32 220kw gts4 with a gtr gearbox. and that i have a exedy HD cushion button thats slipping.
he said to choose between the HD 5puk and the exedy ceremetallic. i read about jim berry clutches on sau and only saw good reviews.
my budget is $650. could i buy a jim berry that suits my car for under $650? or should i go with the ones sliding performance offered me?
this might be a stupid question, does it matter what flywheel i have? (extreme lightened) will any clutch fit any flywheel?
and where is the cheapest place i could get my clutch fitted? im in melbourne.
i was quoted over $700 labour by most mechanics, they said its a 10hr job because its 4wd
sabbadin automotive in melb quoted me $350, it sounds cheap to me but is there anywere cheaper?
thanks
https://www.sau.com.au/forums/topic/220924-cant-decide-what-clutch-to-buy/
For your budget i would recommend an Xtreme HD cushion button.
sliding performance said not to buy a cushion button. i have a cushion button now and it didnt last very long.
the last owner went through 2 extreme HD, im not sure how long he had them for but he said they didnt last long.
what do you think of the exedy ceremetalic?
don't bother with the ceremetalic - won't last long if you drive hard. best off taking the plunge on the Jim Berry clutch. $350 is reasonable for a GTR box clutch fitment. not a 10 hr job if you know what you are doing...
thanks mate
can anyone else comment on the jim berry clutches?
and roughly how much would one cost that suits my setup?
thanks
i can do it in 2 hrs...but ive had too much practice...i quote 3 1/2 hrs to do it for a customer...@ $100/hr so $350 is spot on.
5 puck, cerametalic and berry are all the same friction plates. basicly you should go with what your budget alows for. :down:
hey thanks
if you hadto choose between the three which one would you buy?
Dont last long? I have had mine for a year and took some serious punishment.Second and third gear clutch kicks!
When removed it still had heaps of meat left.
The only time clutch plates wear is when you slip or ride the clutch too much.
Any of these clutches is going to hold your power level,just pick the one you can afford.
hey thanks, yeh i did ride the clutch very often
i think ill just go for the exedy HD
should i get the cushion button or the button? i have the cushion button atm, its reali heavy.
can anyone give me an opinion on the cushion button and button clutches, and which one lasts longer.
thanks
Correct me if I am wrong, but a cushioned clutch simply has a sprung center, which means it will give a little bit when contacting the flywheel.
The plain button clutch does not do this, so if all conditions were the same, the cushioned one would last a bit longer.
For you however, it sounds like it comes down to the pressure plate - it's not clamping hard enough and the flywheel is running on the friction plate causing premature wear.
I have an Extra heavy duty Xtreme in a 290 odd rwkw gtr and I would not go with anything else - we used one at Targa Tas and it took a beating. Took me 3 1/2 years of daily driving to kill my last one - pretty good as far as I am concerned.
Jim Berry's sound like a good option too if you have the spare time to talk on the phone.
Maybe save for another month or so and get something that won't bother you again.
Jim Berry's sound like agood option too if you have the spare time to talk on the phone.
e
i dont think the clutch slipped once the clamping pressure was good for my power. it started slipping when i started riding the clutch exessively. (know i shouldnt ride the clutch)
im pretty confident that the exedy HD has the clamping pressure i need, and that it would last alot longer if
i didnt ride it.
ill definetely give jim berry a call and see what he has to offer.
thanks
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
