Where To Get Turbo To Manifold And Turbo To Dump Pipe Gaskets
@GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different. It's fixed (for now).
Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them. -
The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
