  • Replies 52
who claims your econo goes out the windows :woot: to my knowledge this is lies
after personally driving same car with cat and without mine hasn't changed from a cat
My mate had no cat on his GTR and he reakons that he got really bad fuel economy....so thats where i got that bit of information from steve
maybe the bad econo come from putting his foot down all the time to hear the improved note?
i know thats what happened with my old stato...
my fuel economy isnt the best right now any way, i told simon when he tuned the fc not to worry bout fuel consumtion.
as its not a daily.
if i drive it on both days of the weekend, i easily eat through a tank of ultimate.
my knocked out cat is no probs at the moment! but saying that after i knocked it out i did blow my turbo! but i did put a jazma exhaust on to keep the noise down and i like it quiet! but since the exhaust is already restricting, it doesn't pop flames and smell, and the noise was the same but i did see a bit more top end in my rev range!
more of a reason to hybridge! gt30 woo anyway mine only blew because i was trying to squeeze as much out of it as possible til my cat started to restrict the turbo from spooling anymore! so after knocking out the cat the turbo had nothing restricting it and it span away
had it all fixed today, 3'' one peice dump front pipe from turbo all the way to first muffler, onto the hks rear cannon style muffler.
took out the cat all together as it was pretty much blocked (seen it for myself)
sounds much better, rob did a great job, highly recommended!!!
all up including the dump pipe,extra pipework, flanges and gaskets etc it come to $525.
:down:
nice and cheap craig....now just dont let a cop have a look at that mate....
i dont plan on it lol...
i cant remember who said it, but someone on here said i better hope a cop doesnt hear the screamer on the way to get the new pipe
well, as i was driving past ttp on the way to rampage, guess who pulled up next to me at the lights, yep, the po po.
i was already thinking of excuses and shitin myself, then i noticed they had the windows down, i was sure i was going to get done, it sounded like a bloody tractor!!!
but..they didnt even look at me! thank god.
then i realised, they pulled into maccas, so it was obviously breakfast time, so they had better things to do than pull me over.
it got my heart going thats for sure.
i had a gasket leak on my 33 and it sounded just like yours.....similar to a tractor.......and i cop pulled me over....he thought it was a worked up motor.....i was like duuude wtf lol......i was on the way to the mechanics as well.....dumb cops
mods, please delete any info in relation to the possibility of getting my car defected from this thread.
due to sapol making there presense felt here,
i will be keeping all future modifications to my car, quiet.
thank you in advance, craig.
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
