As the title states.... under load car starts missing around 4200 through to 6k and then revs through fine.... no engine mods done, (that I'm aware of), pretty much always been ultimate fuel (bp is at end of street) on my r34. Any ideas from past experiences...
https://www.sau.com.au/forums/topic/220957-missing-between-4200-and-6000rpm/
From past experiances i had no mods pretty much but regapping the spark plugs fixed it. Everyone will tell you it will be spark plugs which needs to be regapped to .8 or they will say it could be your coil packs. But to start if i was you i would get the spark plugs regapped or just some new ones that are already gapped to that as after market coil packs are expensive and you might not need them.
A search should bring up heaps of results...
This is generally a coilpack issue, using different plugs (BCPR6ES coppers in my case in my old 33) and gapping them to 0.8mm might help but you're masking the root cause of the issue, which is a weak spark. A set of Splitfires or similar should solve it, but maybe see if someone will swap coils with you to test it out first?
yeah bud,
dude it was very random!! it was a flamin mongrel. cos i had nfi wat was wrong went to take it to gavin wood and OF COURSE it ran fine :bunny:.. then on the way home started again so funny but yeah hated it.. 1 day or morning it will be ok.. then on the way home terrible >_<ect so forth lol.. for me i changed afm and got new splitfires/plugs.. but yeah i did trouble shoot first.. trying the cheaper stuff first.. like fuel filter.. did nothing then i changed plugs.. nothing then swapped afm and bought new coilpacks as they were on the way out too.. worked a treat :)
Thanks for all the replies... I tried a search in forced induction, but kinda came up with a lot of stuff I didn't want as well, some of the ones I looked at were same or similar things to do. Coming up to another service so will end up with a major tune once I find a good shop on the northside and see how it all ends up.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
