rear 18x10 -15
front 18x9 -14
Brand new!
these are genuine painted from factory not resprayed!
have never been on any car just trial fitted!.
with brand new tyres kumho ecsta spt
plans have changed and i have to let these go!
very tuff offset and will look mean on any 200sx,skylines etc.
very rare black coloured GT-C's
and toughest dish!! set yourself apart from the rest!
haven't seen much black around at all!
price $3,600 negotiable
pics.
http://i203.photobucket.com/albums/aa166/h...ront_Rear-2.jpg
http://i203.photobucket.com/albums/aa166/h..._/Photo0036.jpg
http://i203.photobucket.com/albums/aa166/h..._/Photo0035.jpg
contact 0406679297... Hoang prefer pickup around Fairfield west area
A friend of mine went to put GTC's on his 33 GTST and had to go to the trouble of getting longer wheel studs so the nut would actually go on and tighten.....
well im guessing he didn't have the right nuts that you get with the rims to specially fit these wheels!...
cause these wheels you need to get a particular nut for it!!! can't just put any nut you please!
anyway's these wheels come with the nuts!.. so that is not a problem here!
so...if you have genuine interest in these wheels pm me
wheels are still for sale!
Edited by blitz1100
the nuts are shank type fyi. sweet rims dude GL with the sale
thankz bloodsword27
yeah they ain't as fat as the usual nuts you see on cars!
there pretty thin nuts!
and fits perfectly for the rims!
come on guys need these gone! throw me a price and ill be negotiable as you are reasonable!!!
who wanna buy my gold gt-c 19 inch for $3500 so i can buy this one..lol
My apologies for aiding and abetting this blatant thread hi-jack but Mikyel, details please. You have PM.
As do you blitz1100.
Free bump for the seller as compensation...
Hi, whats the size of the tyres?
size is
225/40 front
255/35 rear
sorry garage menace i wouldn't have a clue!
size is
225/40 front
255/35 rear
What are the offsets? What vehicle were they trial fitted to? If they fit an R34 GTT / S15 will they fit a V35 Coupe with Brembos?
Anyone re the last?
Edited by Garage Menace
Anyone re the last?
these offsets on my wheels were meant for widebody! perfect fit for the widebody vertex ridge kit s14a they were trial fitted to the s14a on a hoist and stuck out about 50mm on the rear and 30mm on the front! offset is -15 rear, -14 front..
Drooool
Free bump on dat shit!
thanks RBJ3T hopefully some1 snaps these up soon!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
