Hiya, I've just found out that no-one in England can map a PowerFC for a R34 GTT because no-one has the right "lead" to connect it to a laptop (they can map GTR's but the GTT use's a different FC Commander version and needs a new lead to communicate with the laptop) and can only use the FC Commander which isn't ideal. Is there anyone who can get me a lead or tell me where to find one as I assume that your tuners have the right leads as they can map your GTT's.
Any help is greatly appreciated and you'll be able to help map the 1st GTT in the UK!
Cheers......................................................IanH
https://www.sau.com.au/forums/topic/22102-r34-gtt-and-powerfc-question/
Hi IanH, we use the Commander to tune Power FC's. I have only ever seen two types of Commanders for R34's 415-N001 or 415-X001.
http://www.meggala.com/powerfcmodel.html
The above link shows the PFC and Commander models for each vehicle, it might help.
Datalogit have a porgram for laptops to tune (and data log) but as far as I know it is only available for GTR's at the moment.
Apexi Power Excel dealers in Japan have laptop programs supplied by Apexi, but the licence fees are expensive. I don't know of anyone In Australia that is a licensed Excel shop.
Hope that is of some use
Thanks SydneyKid - The GTT needs the N001 Commander and I was sent the X001 so I'll have to change that anyway. Even with the right Commander there is still no-way to connect a laptop (and Commander won't be as good). I'm in contact with Datalogit about a GTT version so I'll let you know later how that goes.
Cheers anyway.....................................................IanH
  • 4 months later...
Ian, did you ever hear back from them about a GTT version? I'm probably going to be buying a GTT in the near future and I was hoping to get it mapped with the Datalogit software.
Cheers,
Michael
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
