Has anyone out there bought cooler piping and cooler from just jap?
Specificly Cooling Pro?
Was looking at the bar and plate 600mm cooler and polished pipe settup for my 32 gts-t.
http://justjap.com/store/product.php?produ...=271&page=2
Anyfeed back would be mad :(
was running a Type 2 on my R33 and could not complain. It all lined up and was a great fit.
Quality and performance was not an issue at all.
I am now running the new "stealth" series and it is the same. Great quality for the price.
For the price, performance and quality i would recommend the justjap cooling-pro Kits as i have had no issues with them!!
Thanks
I used one on my R32 GTS-T, fitted up very well and no problems at all.
Guest
    • By went out the old cluster completely died first it was the odo lcd then the gauges stopped working, Nissan said the board/chip went bad. I then ordered a used one off of amazon. I can transplant the speedo gauge itself I still have the old bad cluster. in fact I am trying to visually inspect to see any differences between the two. The back of the speedos themselves have a different number on the top one has a 5 the other has a 6 i believe printed at the top and the original motor looked a bit larger. On the board itself behind the speedo I saw a few differences looks like towards the bottom the my original board didn't have a resistor at R3. The SMD chip in the top right has some different numbers on it (maybe I can swap these) and the resistor at r16 might be different colors. So the new cluster came from a non turbo but it did have TCS the ebay seller said. hopefully these images will show:  New cluster broken cluster   I will try to transplant just the speedo first.
    • I'll match that and include 3 out of 4 of the speakers in a set of Alpine front splits.
    • *all RB25 s1 if I hadn't said yet, sorry guys haha
    • Yes, the speed sensors are quite different between NA and turbo. Completely different waveform. I'm surprised it's picking up any pulses at all if it is the wrong one. As to the original problem... "the instrument cluster went out". What does that mean? What died and how? Is there any hope that you could transplant teh speedo head from that into the new one?
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
