Cleaning out the rest of the parts in my shed, basically these are most of the parts I have left. Priced for quick sale. Don't mind sending interstate however buyer will have to arrange for the item to be picked up from my place.
Item: R33 Suspension (Full set)
Condition: Used, not sure on quality
Price: $80
To Fit: R33 GTS-t
Contact: 0404 46 43 49
Image:
http://allblitz.com.au/sau/r33susp-1.JPG
http://allblitz.com.au/sau/r33susp-2.JPG
http://allblitz.com.au/sau/r33susp-3.JPG
Item: Front suspension
Price: $40
To Fit: R33 GTS-t
Image:
http://allblitz.com.au/sau/33front-1.JPG
http://allblitz.com.au/sau/33front-2.JPG
Item: Springs x 4
Price: $40
To Fit: R33 GTS-t
Image:
http://allblitz.com.au/sau/33springs-1.JPG
http://allblitz.com.au/sau/33springs-2.JPG
Item: Strut (complete set)
Price: $40
To Fit: R33 GTS-t
Image:
http://allblitz.com.au/sau/33strut-1.JPG
http://allblitz.com.au/sau/33strut-2.JPG
http://allblitz.com.au/sau/33strut-3.JPG
Item: Strut and springs (complete set)
Price: $70
To Fit: R33 GTS-t
Image:
http://allblitz.com.au/sau/33susp-1.JPG
http://allblitz.com.au/sau/33susp-2.JPG
http://allblitz.com.au/sau/33susp-3.JPG
Item: R34 Suspension complete
Price: $70
To Fit: R34 GTT
Image:
http://allblitz.com.au/sau/34susp-1.jpg
http://allblitz.com.au/sau/34susp-2.jpg
http://allblitz.com.au/sau/34susp-3.jpg
Item: G4 Racing Alloy Wheels 17". Pretty sure they're 17x9
Condition: Used
Price: $70
To Fit: Came of an R33 GTST
Image:
http://allblitz.com.au/sau/g4-1.JPG
http://allblitz.com.au/sau/g4-2.JPG
http://allblitz.com.au/sau/g4-3.JPG
Item: R33 GTR Non-Vspec Diff
Condition: Used
Price: $700
To Fit:
Image:
http://allblitz.com.au/sau/gtr-diff1.JPG
http://allblitz.com.au/sau/gtr-diff2.JPG
http://allblitz.com.au/sau/gtr-diff3.JPG
http://allblitz.com.au/sau/gtr-diff4.JPG
http://allblitz.com.au/sau/gtr-diff5.JPG
http://allblitz.com.au/sau/gtr-diff6.JPG
http://allblitz.com.au/sau/gtr-diff7.JPG
Item: JIC Coilovers (Rear)
Price: $100
To Fit: R33 GTST
Image:
http://allblitz.com.au/sau/jic-1.JPG
http://allblitz.com.au/sau/jic-2.JPG
http://allblitz.com.au/sau/jic-3.JPG
http://allblitz.com.au/sau/jic-4.JPG
Item: Momo Indy Woodgrain Steering Wheel (Does not come with the Boss Kit)
Condition: Used, good condition
Price: $120
To Fit: R33
Image:
http://allblitz.com.au/sau/momo-indy1.JPG
http://allblitz.com.au/sau/momo-indy2.JPG
http://allblitz.com.au/sau/momo-indy3.JPG
http://allblitz.com.au/sau/momo-indy4.JPG
Item: R33 GTR Factory Front and Dump Pipes
Price: $300 ono
To Fit: Possibly all GTR models?
Image: Will try and post soon
Item: R32 GTR Front Mount Intercooler (Factory)
Price: $220
To Fit: R33
well ive got a set of the G7 series and wanted to use the G4's for the spares lol was also intersted in the JIC's, is that rust on the thread??..
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
