Hi All,
Does anyone know if there is a stock immobiliser in the V35's?
My Audi had an immobiliser in the ignition which was de-activated by the stock key (had a little transmitter in the key body).
If they dont have one as stock can anyone suggest a good one to install?
Cheers
Lee
https://www.sau.com.au/forums/topic/221088-immobiliser/
it was a dealer-fitted option in the V35
i have one and it doesn't sound when you arm the car but you can sure as hell hear it when you try to unlock the car with the key when the alarm is armed!
alternatively i have spoken to chris rogers about this in the past and there are a few threads on this already - but installing an aftermarket system is definately possible
also, its a mandatory requirement for an immobiliser to be fitted as part of compliance regardless of what the car has so you definately have at least the compliance alarm
cheers,
Warren
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-3897784
cheers,
Warren
Hi Warren
I thought compliance required an immobilser but I kind of dont want to take any chances.
I think I will go and get an alarm installed, I am just a bit warey of people who don't know what they are doing.
P.S. I am trying the clear plastic polish today on my headlights. Just got my car back as it was at the dealer for 2 weeks getting the VTC replaced. Glad I didnt have to foot the $3300 bill!
Thanks for your help
Lee
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-3897820
the advantage of buying a car already in australia, like i did, is that the cars on the yard are already complianced. that means that an immobiliser is already installed and working. the ones they screw up i have no cares about as i won't even know about them! the ones in front of you have been done successfully.
every V35 has an aussie-fitted one and if that is all you want then you've already got one and are wasting your money.
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-3897876
  • 4 months later...
My V35 Premium has a little sticker on the drivers side window / triangle showing a key through an engine with "SECURITY" written under it.
I also got a spare 3rd key that has no remote opening buttons and is a redish colour - not sure what thios key is for?
I am assuming my car has an immobiliser but no Alarm?
I have the RED LED on the dash that flashes when the car is locked and unlocked - but I just sat in the car and locked it with the remote and jumped about - no alarm - then opened the door - no alarm then locked the car with the remote and opened the door with the key... no alarm...
Insurance requires an Australian standard Imob - does anyone know if the stock one is up to spec?
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-4172889
so you have two remote keys and a red valet key.
the valet key will not open the glovebox but opens the drivers door and starts the car.
as for immobilsers :
the car comes with a NATS 2.8 or NATS 5 item from the factory. that one is not Oz compliant.
Oz compliant (to ADR 82/00 ) are mongoose M15 mongoose MX40MK II autowatch 573,674 , Autowatch 446RLI or 446P.
these are really shop dependent. the constant one across teh board is the 573. that is a transponder tag. no tag - no go.
the 446 versions I had put on the list so I can use them on various cars here in brisbane as they are compliant with the ADR82/00 rules.
the other thing on these for Oz stds compliance (for insurance) is the install side of it. there is a standard for this and it needs to be followed.
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-4173774
Sorry to be a pain Chris, but what is the Standard that needs to be followed when installing the immobiliser, is it quoted in the ADR you stated?
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-4174213
no. it is part of the Oz Stds. ADR states how the unit should work and to what vehilces it should be fitted to ( every thing after 07/2001.)
So you follow an Australian Standard for the Alarm install? Is that a document from the Australian Standard Website and if so what number is it?
I always thought that Alarms were just installed as per the Alarm instructions...
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-4177082
far from it. in NSW you need a licence to do them. qld is going that way as well.
I do follow a standard when fitting alarms. its the sole reason I have the name I do - I do it properly.
google aus stds for alarms/immobilisers - should net what you wnat.
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-4177842
  • 2 months later...
hey guys,
just picked up my v35 lastnite...(very happy)..I have a question about the immob.
When I lock the car via the remote i monitor the action from the centre dash LED, it flashes, I guess this is ok.
But I have another LED (marked as 'security') on the drivers side that does nothing....no flashes.
I tried locking the car via the remote, as per normal, then opened the door manually (red key), the car opened and still started successfully!!
I would've thought that the 'immob' would've kicked in and prevented this(?) ((engine from starting)).
I know there is no alarm, that's cool, but I didn't expect the engine to start!.......Is there something I can check to see if the 'immob' circuit is working??...no flashes from the 'security led' makes me curious as to whether the system is working.
I guess my insurance people would like to know too!
Cheers!
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-4303727
  • 1 year later...
Great. Sorry to dredge up this old topic but in preparation for bringing in an 08/09 V36, I have my tried and true Clifford Avantguard 4 unit from my old car that I want to carry across to this vehicle particularly for its Blackjax (anti-carjacking) feature but also for its great performance with its various sensors. This is just too good an alarm for me and I'd like to continue using this beast rather than give it up for something I may not be happy with as its replacement.
I guess with all that I have read in this thread, this alarm will not meet ADR and Australian Standards requirements since the wiring harness is colour coded. That and the fact that I am an electrical engineer but not licensed for this sort of automotive work probably won't help me out here. Am I really stuck with having to pay for someone licensed to install an alarm that they supply in order to meet compliance requirements?
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-4986324
the thing you are going to have fun with is the CAN system in those. whlist the clifford item is good getting it into that car will be fun. I would suggest talking to the installer you used for that alarm. I would also consider the G5 as that IS compliant BUT I'm not entirely sure there is a CAN version of it.
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-4986425
  • 1 year later...
Hey All!
Sorry to bring up this old topic, but in short from reading the previous posts...
Can people please confirm for me (and others) that if you buy a car that is already imported into Australia (by import dealership and/or private) and has compliance, then it has an Australian Standard alarm and immobiliser system or at least an immobiliser system installed and working in order to have compliance?
And that you would only need to go and install an Australian Standard immobiliser system yourself or find a place to do it for you, if you buy a car without compliance or import a car and is yet to be complied?
@Chris Rogers: How and where can you check to see if what type of immobiliser is install in the car?
@ShadowKnyght & superspit: I concur, same thing has happen to me as well? I'm really confused, but I haven't tried to drive it other than been able to start up the engine...
Many thanks in advance!
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-5986345
Hey All!
Dmitiry who USED to work for Nagoya sold me one with no imobilizer, basically knew the compliancer and told him not to put one in there, so dodgy, stay away from him if you can!
Cody at Nagoya is awesome to deal with thank god..
Get a Mongoose M60 or 80 as they work well with our car, they are Australia approved. They have a upgrade kit if you have stock remote for the unlock/lock/boot but as mine didnt i just got the m80/g which came with 2.
Mine didnt have immobilizer either as factory
As for what immobiliser, lock the car, manually unlock using the key, see if u can start the car, if so = no immobiliser. what type is it if it wont start, look at the unlock remote, or go looking for the unit !! (not advised) :)
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-5986364
Does it matter what key is used in this process? im at work and dont have the red key with me and want to test this
well to my horror there is no immobiliser in my car at all FML, just opend it with the key it started, sat in the car locked it with the central then tried to start it and it started right away.
Edited by T4NK
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-5986559
  • 1 month later...
Thanks! What is the recommended way to go, the M80 or the M80 Upgrade? I was thinking the M80 Upgrade since I wouldn't have to carry around a remote, but now thinking it over. I don't THINK there are any good installers or installers that won't mess up the OE for the V35's, in Victoria (that I know of). Unless someone has installed the M80 Upgrade and is working perfectly from an installer in Victoria, I'm gonna go with the full non-integrated system M80 and run it and the OE separately (if think that is possible from what I have read).
If I was to go down the full non-integrated system path, should I stick with Mongoose or go with a Viper?
Edited by 81gSKy
https://www.sau.com.au/forums/topic/221088-immobiliser/#findComment-6042851
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
