Make:R32
Model: GTR
Milage:70-80 000 ks
Transmission: manual
Colour: gunmetal grey
Complied? yes
RWC supplied?
Currently registered? No but have engineers papers & blue slip.
Price: 12k Firm
Contact: 0409 744 904
Comments / Modifications: Standard except for a GFB boost valve, car is in very good condition urgent sale due to other responsibilities, car is running approx 15psi & is making 200kw @ All four wheels. ALSO REASON WHY CAR IS CHEAPER THEN USUAL GTR'S IS BECAUSE THE LEFT BACK WHEEL IS BENT A LITTLE BIT AS YOU CAN SEE IN THE PICTURES HAVE HAD IT QUOTED TO BE FIXED UNDER $400. :D
is that left rear tyre wearing badly or is that just dirt or something?
*edit* don't worry i jsut realised that it is in fact worn to the belts..carry on
Edited by Black Widow
so how often do you run it in 2 wheel drive mode??
and how many gutters you hit in it??
why so cheap, there must be other reasons?? u just dont sell a low km GTR for that cheap becuase one rim is buckled.
im not trying to waste ur time. so dont flame me, just asking some questions
if i were you i would buy a set of $1000 rims and sell the car for $15,000+
but GL with sale anyway
I know if I had the money I wouldnt be whinging, I would be on his doorstep giving the once over and driving away a happier man =)
Good luck to whoever buys it....
mate rims r fine... :P
its something to do with the control arm...
reason for being so cheap is one no rego & 2. I want it out of my drive way asap as i have a few other cars and a mortgage to pay and theres no necessity for having this just sitting around...
im driving it, hahaha
$$$ 9500
and makes 232 awkw on 11.37 psi.....
changed plugs and intake pipes.
lol stick that up ur ass's, sometimes time is money for some people
and if they cant be f*ked with things they will let them go cheeap, there is no scientific explanation
they just want it gone...
good buy and was it just rear subframe bent and control arms????
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
