ok its been worrying me a fair bit lately, it dosent take a genious to understand that on a cold engine there is no oil around the engine on a cold startup, so on that note, just a quick question, is the car meant to run at higher revs on cold startup then as it gets warmer the revs come down? it almost brings a tear to my eye when i start the car up in the morning and it revs its tits off and slows down.
is this normal?
https://www.sau.com.au/forums/topic/221100-revs-on-cold-startup/
the longer the engine is cold, the worse the performance, economy and emissions are
the engine's ideal operating temp is 80deg so it does everything possible to heat itself up to 80deg
so below 80deg the ecu adds in fuel and ignition correction to get to operating temp quicker
paul on that comment, are you saying that the longer it takes the engine to warm up to operating temp, the worse it will performe etc.? as in for best performance and economy (at operating temp) its best to warm the engine quicker?
its better to have the engine warm up as quickly as possible, the best way to do this is drive it around normally but dont trash it
tactics such as leaving an engine idle for a 5 minutes before you take off for work is bad, as engine runs colder for longer than it normally would
so drive it around, just dont trash it till the engine temp is up near 60-70deg then its ok for some normal load etc
i usually just baby it around for first few minutes by the time im near the freeway entrace the water temp is well past 55deg so its fine after that
what happens if you do happen to trash it when its cold? does it wear out the engine more?
not that I do it :down:
i used to have a VH commodore, and when starting, would have to apply 50% (keep the engine running) tactics, and 50% (not let it die) tactics, so naturaly the lower the revs the better in that case, because it had no oil at the engine when starting. thats why i asked :down:
An idling engine below 2,000rpm is doin far less damage then when you first pull away and change gears at prolly 3,000rpm+ with the engine under load... So I would not shed a tear on startup, just dont rev out the car at all in the first 10mins... It suprising how long the oil gauge takes to rise... made me realise how useless the water temp gauge is!
Edited by r32line
so your saying its better to let the car warm up in idle for 5 mins?
No, it's not.
Everything else will be stone cold if you leave it idling for 5 minutes...Start it up, wait about 30 seconds, then drive off keeping the revs to a minimum, and everything (gearbox, engine, diff etc) will all warm up
wow, this goes against everything thats been told in the past, if you ask anyone they will say let your car warm up for 5 before driving, why has that been the case all these years and then someone says its bad? surely it must be better to let it idle for 5, otherwise how did everyone come to think that? im not arguing or anything, im just curious, did older cars act differently? and letting older cars warm for 5 be better than driving straight away?
if nothing else (but theres plenty else), the rich mixtures will tend to foul your plugs by idling for minutes on end while cold.
i can practically light my exhaust fumes on cold start lol. so i prefer, start, buckle up, drive off sensibly, wait till oil pressure settles to normal levels, then have fun.
Edited by Munkyb0y
I think in the old days especially if ur carby/choke was out of tune it was probly better to let it idle to warm up rather than have it stall in the middle of the road.
These days u just start up and drive light/normally until the temp is up....
why would you idle for 5 mins? The motor, if under normal mild load, will warm up faster.
if you idle for 5 mins, the gearbox oil, diff oil, all bearings etc are still stone cold.
so you think after 5 mins it's good to go? the engine maybe, but everything else is still stone cold.
best to start up, drive normally after 30s and let it all come up to temperature
    • ..could be worse... but out here, renting private affords some luxuries ...we've even been told the Sept dateline isn't critical, and I'd rather move stuff in the cool of winter, than slogging it out in the heat. Recall we were talking about the million dollar view this place has?...that's what he got for it... (won't be so nice when the quarry happens at the back in the future...lol..)... ...cool, I'll stick the wiper motor in a wee box...umm.... the pinny is GLX trim ~ I think that's about as close as it gets to Silo spec when it comes to the S2 pinny...ie; electric mirrors etc etc...dunno about the trip computer/wiring...I do electronics repair, I'd be willing to take a look at it for you. As you saw, all the dash is there in that car..and thinking about it, it'd be easier to pull the whole center section out, rather than just the ashtray and rails, but your call...
    • The "sacrifice of low end" is now basically irrelevant in 2025. Turbo/ecu/fabrication/and other tech advancements gives a vast array of options to mitigated any of it. My setup now is a fantastic example of this. 300whp / 20psi @ 3500rpm from a 600hp turbo setup on a notoriety low reading Dyno Dynamics roller dyno, is almost unmatched on all of SAU and other forums. The only other turbo i've seen that can achieve this is a BW EFR + twin scroll / twin gates etc etc etc... ps. tuned by Matty Spry at P.I.T.S as far as getting to the 600 figure, while enlarging your itb's alone probably won't get you there, as Sucram has stated above, it will certainly help. Just do it Predator1 my brother hahaha 🙂
    • I use Taaarks/efi solutions ones. Years, and no issues.
    • At the Botany heavy vehicle inspection centre. At the time there were only 2 locations that did IM240 testing for free, the other location was at Penrith. I did a quick google, seems like the Botany and Penrith inspection centre is closed now though About an hour of my time.  At the time you could. They are closed now   No it was Government run, the site was attached to the RTA from memory. The guys running it at the time were awesome, if you didn't pass the test, they handed you the results and said make changes to your car/tune and have another go later. You drove in registered, failed, and drove out registered.   Obviously though if you were defected, sent there, failed. You remained unregistered.  From my 5 minutes of research (have a look at the date on my test results) looks like things have changed. So, I can't see any way to get this test done for free now Seems like you'll need to call around the engineering places doing the Vehicle Safety Compliance Certification Scheme or call around workshops with a dyno and try and get a RG240 test. No idea how expensive that is though or how easy it is to find a place offering it.  Bit depressing learning about this now. The first car I had engineered in NSW cost me about $250 all up.... So kids these days can't buy houses, looks like getting your car legal and engineered in NSW is another thing on the list of things they can't afford. Great.
    • That makes sense. Thanks!
