like im sure many of us i drive my gtr to work for a bit of fun but with petrol its getting outs control lol
anyone thought of putting lpg on thier gtr?
i think gas research would be the only way to go due to the injection not beeing able to keep up with the power of gtrs.
previously i converted a 180sx with a ca18det (4 yrs ago ) and it produced 220kw atw, on gas research,
any thoughts?
https://www.sau.com.au/forums/topic/221155-gas-on-a-gtr/
any thoughts?
Fark gas research the shit is archaic... lpg injection is the only way to go. I am tuning a 280-odd rwkw gas research soarer ATM and well yeah... injection FTW Gas Research FTL.
https://www.sau.com.au/forums/topic/221155-gas-on-a-gtr/#findComment-3899387
sorta off topic but once all these conversions are done and everyone's paid at least 1g for it.. what do you think the government will do for tax and shit on the gas? the price will shoot up too.. i think it depends on the car and how much you fill up.. get ur monies worth..
thats if you can do it that is
https://www.sau.com.au/forums/topic/221155-gas-on-a-gtr/#findComment-3900363
HEY GUYS, My R34 is injected, iv maxed out my 6 injectors at 250rwhp so to get to the majical 300rwkw mark i would have to go to 12 injectors and 2 gas convertors. the gas injectors can flow alot more IF you run them on custom fuel rails. as the standard Keihin 1's are a major bottle neck.
regards
chris
https://www.sau.com.au/forums/topic/221155-gas-on-a-gtr/#findComment-3900915
With gas research there is some nice example's out there like a mustang with a 4ltr engine making 470kW atw. But it cost lots of money cheaper to stay with petrol.
dinosaurs for dinosaurs :blink: im notsure if many people who comment on the gear have actually used it.... gas can be real laggy to respond to throttle inputs and ALL the gas research units ive driven or seen suffer from this, the direct injected stuff is exactly like petrol... no throttle lag.
https://www.sau.com.au/forums/topic/221155-gas-on-a-gtr/#findComment-3902599
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
