hey guys,
i've had a safc in my car piggy back off the standard ecu for a year or so.
so 2 weeks ago i blew my turbo, the tune got a bit screwed up, but the standard ecu manage to sort the problem out it self. allowing the car to still be drivable, but just no boost and chews a bit more petrol.
due to a turbo upgrade, i purchased a apexi power fc, for rb25det.
ok i so took the standard ecu out, put the power fc in it's place, with the safc still piggy backing off the power fc. make sense? (safc and power fc running at the same time)
the car starts fine, and is drivable.
ok so i took the safc out today, and now the car wont start with the power fc by itself?, so i plug the standard ecu back in and the car starts again.
hmm so the question is:
why does the car not start with the power fc in just by itself? (the car would start for like 1 second and then stall.)
is there something wrong with the power fc? I initiated the power fc a few times (reset it)
when i go into the setting of the power fc, like 30% of it is in japanese, it that normal? and on the 'program version' menu, it said rb25det version...so it should the right power fc right..?
is the blown turbo causing the power fc make the car stalk?
im just worried the power fc isnt the right version for my car (r33 gtst)...but the serial does have 'Pfc rb25 9706' on it - theoretically if it's the wrong version it shouldn't allow the car to start even if it had a safc...
cheers guys...i know i asked like 20 question just then
steve
Edited by ztuned
https://www.sau.com.au/forums/topic/221200-power-fc-safc-ecu-wtf/
remove the safc
reset the powerfc
turn the car to ACC but dont start it
check the basic sensors, disable the boost kit
start car and perform self idle procedure
dont touch the throttle during the self idle, if you do, it will kill the idle program, which gives it the instant-stall affect when you start it
it sounds like you have two issues - 1 remove the safc, 2 do the self idle learn correctly (it sounds like you arent resettting it)
if you reset it correctly and start it without reading the instructions the engine check light will be on
yeah some of the menu's are in japanese and you have the correct version
the powerfc faq has all of this covered already- you should take a few moments to read it (its in my signature)
Just check the AFM wire is plugged together aswell. One end of it goes to the safc, then from the safc back to the other end which sends the modified signal to the ecu. If ya dont reconnect it in the middle u dont have an afm signal and ya car wont start.
Did the same thing accidently once :)
I had the same problem with an rb25 powerfc. I had 2 both with rb25 serial. I reset both of them. 1 would start and drive fine. The other would stall at idle but would drive if you keep the revs above 2000rpm but under 2000rpm it would just die. Even if you reset them to factory defualt they dont seem to work the same.
Edited by Brokenz
yep. for sure I would say it's a wiring problem. Power FCs seem to be much more sensitve to poor wiring and particularly to poor earth/poor batt volatage. check and double check all the wiring that the SAFC was involved with.
yep, it turns our it was the safc wiring from before. the blue/orange wire was cut...had to reconnect it and the car started after disabling the boost control kit :D thanks guys
i did the 30mins idle procedure. i could hear something weird when the air con is on, revs jumps a little bit every now on then..but i think thats normal. i can also hear a 'zap zap zap' noise every 30secs when the air con is on. it's not knocking, i check the knock sensor on the pfc.
every time i hear the zapping noise, the air con sensor flashes on the pfc.
i took a pic when the aircon is on:
and are the other black dots meant to be there? keeping in mind that my car has a blown turbo...so it's shit lol
this is covered in the PFC FAQ, its in my signature
you should read it...
http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#20
Sensor Check
MAIN MENU, ETC, SENSOR SW / CHECK Look for any sensor names highlighted in BLACK background or any flashing sensors. Any highlighted in black indicates a problem. The engine check light will also stay on if any of the sensors aren't working (highlighted in black). This is not to be confused with the black DOT switch on / off sensors.
so in your screenshot we can see
NTR is on - gearbox is in neutral
IGN is on - ignition is on
A/C is on - air con pump is on
ECC is on - main engine control
F/P is on - fuel pump control
FP1 is off - fuel pump not currently running
02H is on - 02 sensor heater control
ACR is on - air con something
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
