I just got a twin plate nismo clutch installed in my R32 GTS-t about two days ago. It is a totally different feeling, but I'm still in the process of breaking it in so I can't have too much fun. Recently when shifting from 1st to 2nd quickly it almost feels like it's grinding, no sound just doesn't feel smooth. It's the same thing when shifting fast from 2nd to 3rd, but not as bad. I know they changed the transmission fluid with the clutch. Any ideas?
https://www.sau.com.au/forums/topic/22121-changing-gears/
I just had a 2800lb Put in my 32gtt and after 20 mins of medium street driving it won't easily go into any gear when stopped. And in the last couple of days, I have missed the all too important shift into 2nd because the clutch doesn't seem to be engaging properly. I went for a light shift into 3rd last night, and it ground with the clutch fully engaged????
Should I wait for a bit more wear to see if it improves? it's probably seen 700kms since it's been in?
Cheers,
Michael
https://www.sau.com.au/forums/topic/22121-changing-gears/#findComment-473635
