hi, just wanted to confirm the remours ive been told about the r34 GTT auto trans. Can you change it over for an apexi copmuter and get it tuned with out any problems or do you still have to keep original comp and use a piggy back ? whats the best way to change/or piggy back it with for better perfomance ?
https://www.sau.com.au/forums/topic/221227-computer-upgrade-r34-gtt-auto/
power fc will work, however Id strongly suggest a good auto gearbox shift kit
over time the gearbox will die an ugly death tho, will eventually need a rebuild
Wash your mouth out! POWER FC WILL NOT WORK ON AUTO R34's once you remove the ECU, you've also removed the ECM that controls the tiptronic, you *WILL* be stuck in 3rd gear, do not pass go, do not collect $200
ah ok.
my bad. soz for bad advice.
I said shift kit, as that will help minimise the gear change time, seeing that the P-fc has no ignition retard on gear changes.
meh, piggyback it then :O
or talk to Toshi, Im dealing with him atm for a remap chip for my stagea (r34 plug). I had an r34 gtt power-fc and assumed itd work for an r34 like it would for my non-neo rb25det, but decided I cant afford a shagged gearbox.
ah ok.
Yeah the Stag used a similar setup to the R33's remote ECM that still controls shifts...much like the R34 25GT, the GTT got the raw end of the deal so can't use the FC
I'm going for +1 for remap as well, I've got a USB remappable daughterboard, cost me all of $200 and lets me frig with the tune to my hearts content via laptop.
ok, is there any suggestions to whixh brand ecu that will work with it, or it wont work ? is there anyone out there who has done it? will i kill my transmission some time soon or it ll be ok for the longrun if looked after with care ?
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
