hi, just wanted to confirm the remours ive been told about the r34 GTT auto trans. Can you change it over for an apexi copmuter and get it tuned with out any problems or do you still have to keep original comp and use a piggy back ? whats the best way to change/or piggy back it with for better perfomance ?
https://www.sau.com.au/forums/topic/221227-computer-upgrade-r34-gtt-auto/
power fc will work, however Id strongly suggest a good auto gearbox shift kit
over time the gearbox will die an ugly death tho, will eventually need a rebuild
Wash your mouth out! POWER FC WILL NOT WORK ON AUTO R34's once you remove the ECU, you've also removed the ECM that controls the tiptronic, you *WILL* be stuck in 3rd gear, do not pass go, do not collect $200
ah ok.
my bad. soz for bad advice.
I said shift kit, as that will help minimise the gear change time, seeing that the P-fc has no ignition retard on gear changes.
meh, piggyback it then :O
or talk to Toshi, Im dealing with him atm for a remap chip for my stagea (r34 plug). I had an r34 gtt power-fc and assumed itd work for an r34 like it would for my non-neo rb25det, but decided I cant afford a shagged gearbox.
ah ok.
Yeah the Stag used a similar setup to the R33's remote ECM that still controls shifts...much like the R34 25GT, the GTT got the raw end of the deal so can't use the FC
I'm going for +1 for remap as well, I've got a USB remappable daughterboard, cost me all of $200 and lets me frig with the tune to my hearts content via laptop.
ok, is there any suggestions to whixh brand ecu that will work with it, or it wont work ? is there anyone out there who has done it? will i kill my transmission some time soon or it ll be ok for the longrun if looked after with care ?
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
