Hey Guys,
Just wondering about whether i'll need to upgrade the ecu, or add a piggyback or not even bother?
Currently my car is stock, other than a cat-back exhaust and air filter.
I aim to keep the car as stock as possible, but also to get as close to 200rwkw as i can without changing turbos/internals, with the goal being performance, efficiency and reliability (it's my daily driver)
So my planned mod path thus far looks like:
* Front/Dump pipe + High flow cat
* Larger Intercooler (e.g. r34 side mount to keep the stock look)
* Boost it up a little, say 10PSI
** also considering a water injection kit **
My question is: with this relatively small list of modifications, do i need to address the ECU to make the most of them? And if so, which path to take - pfc, safc, emanage or other?
https://www.sau.com.au/forums/topic/221232-aftermarket-ecus/
  • Replies 42
this has been covered to death sorry - you really should try searching
there are lots of modification guides, how-to's and many step by step guides
even documentation like the PFC FAQ covers the PFC vs the SAFC and other common ECU's
all of the information is out there, you should just search and read it
but yes, in summary a stand alone ECU will give you all the benefits you need
this will include fuel economy, response, power etc
I have the emanage and it works really well for me. Considering the mods you have, it would work great for you as well...
That being said, so would a PFC, but the Emanage is considerably cheaper and easier to install... Less tuners know them though.
pfc is probably the best one as there's a lot of people that can tune them ..but the cost is rather high (both chip and the tune itself). However you can score them on japanese auctions for a good price if you're lucky .. I just got an R34 GTT PFC off japanese auctions for $160 ($270 or so after all import costs) using importmonster.com.au so saved $7-800 right there ;D
a full PFC tune should cost $500
i cannot understand how a full PFC tune would cost anywhere near $1000
for $1000 i would want full documentation of the tune
how its setup, what to expect, a backup of the tune on a floppy disk
complete map dump and every single value on the 20x20 map changed from std
its complete overkill and lunacy, a std $500 should be fine for 9 out of 10 setups
Sorry to hijack, but also in a similar situation my self.
The OP stated he wants to keep the car "stock locking".
How stock can u get a PFC to look. Does it hide tucked away or is it something that a cop can shine his torch on and say "defection time!!!"
If it is notcied, how easy is it so swap out and put the stock ECU back in.
My mods are as follows and i figure a PFC would be next?
R33 Gtst
3" turbo back exhaust (split dump/front)
Highflow cat
FMIC (Blitz LM style which return back to stock pipes - so no hole needed)
Boost @ 11psi (bleed valve)
Thanks
Edited by Ricos
the PFC and the stock use are the same type of case
just the apexi unit has the hand controller port and an apexi logo on the case
you can swap over the std ecu lid with the PFC lid so that there is no apexi logo
the PFC is a direct fit unit, true plug and play
so if you are caught out you can undo the PFC
slot back the STD ecu and the car will start first crank
no wire changes etc are needed to go between std ECU and PFC
If you dont have a hand controller you can just as easily leave it where the stock ECU resides, passanger footwell kicker pannel.
How easy is it to swap over? Just undo one screw.
Now Im going to hijack,
With such simple mods why not just use a Apexi SAFC?
PFC's to me seem like overkill for such simple mods. You only need to play around with the Air fuel ratio and perhaps the timing.
Why not just use an SAFC that can be had for $200?
Well that's the reason i raised the post initially - i wanted to know if i needed to go full blown ecu replacement, or if a piggyback would be enough. Though i thought that timing is not something that the SAFC could adjust... and i would need a PowerFC if i wanted to change timings.
Timing is adjusted from the engine bay..
no, sadly it's not. base timing is SET in the engine bay, and once set to factory spec needs to be left well alone. to adjust the timing map you need a power FC, or chip, or whatever but an SAFC simply alters the voltage signal between the AFM and the stock ECU which alters the fuel mixture.
LOL....floppy disk, they still around????? :P
if u plan on going for another turbo and etc. go a pfc. but with the mods u have now i recommend a safc neo.
PLEASE PLEASE PLEASE dont get a EMU...i know i say it all the time...but they are utter shit!!!
ultimately pfc...but that may be a bit extravagant for the mods u have now
Edited by r33cruiser
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
