Hey Guys,
Just wondering about whether i'll need to upgrade the ecu, or add a piggyback or not even bother?
Currently my car is stock, other than a cat-back exhaust and air filter.
I aim to keep the car as stock as possible, but also to get as close to 200rwkw as i can without changing turbos/internals, with the goal being performance, efficiency and reliability (it's my daily driver)
So my planned mod path thus far looks like:
* Front/Dump pipe + High flow cat
* Larger Intercooler (e.g. r34 side mount to keep the stock look)
* Boost it up a little, say 10PSI
** also considering a water injection kit **
My question is: with this relatively small list of modifications, do i need to address the ECU to make the most of them? And if so, which path to take - pfc, safc, emanage or other?
https://www.sau.com.au/forums/topic/221232-aftermarket-ecus/
  • Replies 42
this has been covered to death sorry - you really should try searching
there are lots of modification guides, how-to's and many step by step guides
even documentation like the PFC FAQ covers the PFC vs the SAFC and other common ECU's
all of the information is out there, you should just search and read it
but yes, in summary a stand alone ECU will give you all the benefits you need
this will include fuel economy, response, power etc
I have the emanage and it works really well for me. Considering the mods you have, it would work great for you as well...
That being said, so would a PFC, but the Emanage is considerably cheaper and easier to install... Less tuners know them though.
pfc is probably the best one as there's a lot of people that can tune them ..but the cost is rather high (both chip and the tune itself). However you can score them on japanese auctions for a good price if you're lucky .. I just got an R34 GTT PFC off japanese auctions for $160 ($270 or so after all import costs) using importmonster.com.au so saved $7-800 right there ;D
a full PFC tune should cost $500
i cannot understand how a full PFC tune would cost anywhere near $1000
for $1000 i would want full documentation of the tune
how its setup, what to expect, a backup of the tune on a floppy disk
complete map dump and every single value on the 20x20 map changed from std
its complete overkill and lunacy, a std $500 should be fine for 9 out of 10 setups
Sorry to hijack, but also in a similar situation my self.
The OP stated he wants to keep the car "stock locking".
How stock can u get a PFC to look. Does it hide tucked away or is it something that a cop can shine his torch on and say "defection time!!!"
If it is notcied, how easy is it so swap out and put the stock ECU back in.
My mods are as follows and i figure a PFC would be next?
R33 Gtst
3" turbo back exhaust (split dump/front)
Highflow cat
FMIC (Blitz LM style which return back to stock pipes - so no hole needed)
Boost @ 11psi (bleed valve)
Thanks
Edited by Ricos
the PFC and the stock use are the same type of case
just the apexi unit has the hand controller port and an apexi logo on the case
you can swap over the std ecu lid with the PFC lid so that there is no apexi logo
the PFC is a direct fit unit, true plug and play
so if you are caught out you can undo the PFC
slot back the STD ecu and the car will start first crank
no wire changes etc are needed to go between std ECU and PFC
If you dont have a hand controller you can just as easily leave it where the stock ECU resides, passanger footwell kicker pannel.
How easy is it to swap over? Just undo one screw.
Now Im going to hijack,
With such simple mods why not just use a Apexi SAFC?
PFC's to me seem like overkill for such simple mods. You only need to play around with the Air fuel ratio and perhaps the timing.
Why not just use an SAFC that can be had for $200?
Well that's the reason i raised the post initially - i wanted to know if i needed to go full blown ecu replacement, or if a piggyback would be enough. Though i thought that timing is not something that the SAFC could adjust... and i would need a PowerFC if i wanted to change timings.
Timing is adjusted from the engine bay..
no, sadly it's not. base timing is SET in the engine bay, and once set to factory spec needs to be left well alone. to adjust the timing map you need a power FC, or chip, or whatever but an SAFC simply alters the voltage signal between the AFM and the stock ECU which alters the fuel mixture.
LOL....floppy disk, they still around????? :P
if u plan on going for another turbo and etc. go a pfc. but with the mods u have now i recommend a safc neo.
PLEASE PLEASE PLEASE dont get a EMU...i know i say it all the time...but they are utter shit!!!
ultimately pfc...but that may be a bit extravagant for the mods u have now
Edited by r33cruiser
    • Update time!  The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago.  I also finally got the rear lip painted and fitted.  I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy.  Close out with some nice pictures of the cars and a sneak peek of what's next.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
