I might be on re-runs but could a someone please tell me if its simply a matter of cutting the right wire [which is?] in an r 34 gtr to diable the 180 klm speed limiter. I Know it has been covered with regard to 32 and 33's i am just wondering if it was the same in the 34's.... cheers
Edited by Duncan1
https://www.sau.com.au/forums/topic/221243-r34-gtr-180-speed-limiter/
i dont think you can jsut cut a wire. but can i ask why would u want to remove the 180km so badly? do you do alot of track work? or is it just a street car?
if ur planing to mod your car in the future just hook up a power fc
Yeah i agree and will get a pfc in the not too distant future, but i will wait till i can afford a few more things like injectors, turbo's etc then get it tuned hopefully just the once. Yes the idea is to track the car at qld raceway and the mt cotton hillclimb [180 not a chance there!!]
If the car is mostly stock the power fc can be installed and used with the factory map, Its just slightly tweaked versions of the standard ecu maps. Mine has been running fine on the factory map for 12 months now.
Thanks mate,
Not such a bad idea, i know if i had a pc i would want a tune straight away though!!! viscious circle!!! :blink:
just cut the wire leading to the flux capacitor
You Guys are hilarious.....and so informative!! :woot: lol. Looks like i might have to get a pfc, cause i reckon this will end up being a gee up and i will end up cutting the wrong wire!!!!!
You can do anything you want to your car - cut wire 53, use Homebrand motor oil, clean and reuse the spark plugs etc.
FFS - you've laid out plenty for this vehicle and you want to take shortcuts?? If you want to exceed 180km/h, obviously you want to use the performance that the car is capable of.
Fit and tune a PFC. The whole excersize shouldn't cost you more than $2k, of which you will recoup half of this if/when you eventually sell the PFC.
Apreciate your sentiment Gav, but lets be realistic, by-passing a 180kmh speed limiter is quite different to running a car on homebrand oil, and the car is essentially stock so i feel Nissan's computer is probably more than capable of doing the job sufficiently well. If there are no negatives i.e Hicas shutdown, then i would be happy to cut a wire. so mate if you can help, that would be great.... :woot:
I don't have a wiring diagram for a BNR34, but I would say there's a better than 50/50 chance that the signals from that wire are used for more than just the speedcut function in the CPU.
UAS has an HKS Speed Limit Defender advertised on their site for $280.
http://www.uniqueautosports.com/pricelists/pricelist_hks.htm
Give that a go if you don't want to commit to a PFC and tune at this stage.
Thanks mate, appreciate your help. will take a look...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
