PM Hakujin1977 he has a black 93 if im not mistaken. its got pods n front mount, boost controller, rims and suspension and also a gtr front bar n bonnet. He wants to sell but his lazy.
https://www.sau.com.au/forums/topic/221248-r32-gts-t/#findComment-3931018
