have my 89 r32
ts got 240 rwkw on 15psi with heaps more potential.
-rb25 motor and gearbox.
-fmic
-has 102,000 on chassis motor not sure.
-been told it has a mod diff but not sure. done before import
-aftermarket fuel pump. not sure what it is done before import
-remapped r32 ecu for rb25.
remap was for standard smic, airbox and turbo as well as stock dump and stock exhaust to cat. ran 200rwkw on 10psi
rev limiter reset, no boost cut and no top speed cut
if remapped to new mods would make much more power.
-to4e top mount turbo with custom install
-turbo beanie. just been installed 1 week ago
-turbosmart pro gate 38 external wastegate with slip piece for screamer or plumb into exhaust
-full exhaust with custom dump
-ebc with high low boost. low is 10psi high is 15psi.
-ebc also has turbo timer not connected as well as
boost guage
output for nos and or water spray or what ever you want.
peak boost and average boost
current running voltage.
other stuff i cant remember.
tein ha coilovers.
cusco sway bars. f*kn massive about 35mm for front and rear
nismo 260kph dash doesnt look like its been tampered with.
flared rear guards to fit 18x11's which are on it atm.
upgraded 32 interior with no rips or tears.
genuine gtr front bar
panasonic head unit
2x jbl amps
jbl splits
2x jbl subs in custom box
jbl rear 2way speakers
momo steering wheel
have a 5inch tacho with shift light not installed.
i have the import approval papers
regency paperwork for compliance etc.
was insured for 17k full comp but since then added
front bar, stereo, wheels, suspension, ebc, turbo
prolly a few more things that i cant remember.
goin for full paint in 3days.
