Sellin my xbox 360. Has 2 controllers, the mic thing for online play as well as the new GTA, Tony Hawk, and dead or alive. I would like to get $450 but open to any reasonable offers. Only reason Im selling is because I will be leaving the country.
Also have a Sony 42" LCD 1080p, the high end one that is up for grabs, want $2500 but again open to offers. Both less then a year old.
Im in Sydneys northern beaches. Pick up only please.
Contact via email [email protected] or mobile 0416627645
https://www.sau.com.au/forums/topic/221272-xbox-360/
Sorry I hadnt replied yet, been real busy. I will post the information asked for tonight but the tv is the one with the glass frame around it, the high end one. Not in a big hurry to move these items just yet so if someone wants to work something out please pm or email me.
https://www.sau.com.au/forums/topic/221272-xbox-360/#findComment-3913286
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
