Hey guys got a staggy series 2 engine in the 32 gts4 at the moment. Was running pretty well with gt2871 turbo s15 injectors q45 afm and remapped ecu... took these all out and put it back to standard and now its having massive problems starting.
Car currently has:
Front feed plenum with larger throttle body
Rb25 neo afm
Series 1 afm (engine is series 2 but people have told me it doesnt matter)
Series 2 coil packs
stock rb25 injectors
Stock turbo
These are the onyl things that have been replaced
Its struggling to start.. have got it started a couple of times but runs like dog shit.
Plugged a power fc in .. still ran like shit and struggled to start.. obviously tuned differently but ..
Have injector pulse.. have spark..
Plugs foul up very quickly.. cleaned them numerous times..
Pull the cas out and spin it and injectors click.. not completely fluently but still click...
So given that.. im really not sure where to go from here
Any ideas would be much appreciated
if the stock ecu has been remapped to suit s15 injectors and q45
and you put the stock parts back in, it will run like a bucket of crap
likewise with the powerfc - i would expect same results
overfuelling, mega rich and just a boggy tune
my advice would be to put the PFC in and DATA INIT to factory defaults
then it should start first stop providing you have factory afm and injectors
or get yourself a standard s2 r33 ecu for 150 or so
well the best way is to list all the possible alternatives, then to cancel them out 1 by 1 effectively till you find out what it is. Now could it be theres not enough petrol?
Yeah heaps of fuel in the tank
Been told series 1 ecu should work but im having my doubts
an rb20det ecu was remapped.. but that has been removed and replaced by a stock series 1 ecu no remap
S1 no go with the coils you have
