Does anybody know how Nissan parts treat older stock?
I am trying to get a few parts for my 240k, and i have been told that some of them should still be available from nissan.
I have an old Parts manual which gives me a part number such as 96935-R3700 (rubber gear boot insulator) I spoke to a relatively new nissan spares dealer and they said their nissan warehouse program did not recognise the part number, he tried 5 other part numbers for various parts too.
Does anybody have any insider knowledge in how i should be going about chasing up these parts? or if there are any dealers around willing to go through the pain of tracking down old bits.. or are they just not available after a certain time period (ie. they dump their old stock)
Kent
https://www.sau.com.au/forums/topic/221280-buying-old-parts-from-nissan/
Kent, Try Hornsby Nissan, or try talking to Dave at Macarthur Nissan Spare Parts, they are very helpful for me, they can tell you straight up if it exists or is obsolete or it supersedes to something else. Do you have a picture or dimensions or both, maybe we can compare the R30 bits to it.
Cheers, D
if you want I can try and look up the part in FAST. I need a VIN# and description of the part I am looking for. But on first glance the part# looks same format to current part numbers.
You could also try contacting slide or similar on the forums and see if they can source the part in japan
Hi Duncan,
thanks, but the FAST software doesn't go back to the 70's (unless you have one which does, in which case i would be greatly interested :( )
i have the physical parts manual for the car which lists the numbers, but i am not sure how nissan would advertise the superceded numbers etc.
I spend several hours looking for 70's datsun parts per week. Repco/bursons can get very basic stuff (think wheel cylinders, gasket kits etc), and that's about it. Nissan dealers have generally sucked in my experience, they seem to have a deep-seated loathing of anything more than a ten years old. I'd be combing ebay and importmonster, and join a club like the Nissan Datsun Sports Owner's Club. I can get my mitts on some second-hand 240k bits. PM me if you get really stuck, and Ill see what's in the shed for you.
I work at a nissan dealership, there are still manuals with all the parts and numbers (and crash repair catalouges) for pretty much every australian delivered datsun, including the old skylines. also can try nissan FAST, im pretty certain I saw the c210 and c110 on there last time i looked.
whether or not you can find any of the parts in stock somewhere is another thing.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
