Does anybody know how Nissan parts treat older stock?
I am trying to get a few parts for my 240k, and i have been told that some of them should still be available from nissan.
I have an old Parts manual which gives me a part number such as 96935-R3700 (rubber gear boot insulator) I spoke to a relatively new nissan spares dealer and they said their nissan warehouse program did not recognise the part number, he tried 5 other part numbers for various parts too.
Does anybody have any insider knowledge in how i should be going about chasing up these parts? or if there are any dealers around willing to go through the pain of tracking down old bits.. or are they just not available after a certain time period (ie. they dump their old stock)
Kent
https://www.sau.com.au/forums/topic/221280-buying-old-parts-from-nissan/
Kent, Try Hornsby Nissan, or try talking to Dave at Macarthur Nissan Spare Parts, they are very helpful for me, they can tell you straight up if it exists or is obsolete or it supersedes to something else. Do you have a picture or dimensions or both, maybe we can compare the R30 bits to it.
Cheers, D
if you want I can try and look up the part in FAST. I need a VIN# and description of the part I am looking for. But on first glance the part# looks same format to current part numbers.
You could also try contacting slide or similar on the forums and see if they can source the part in japan
Hi Duncan,
thanks, but the FAST software doesn't go back to the 70's (unless you have one which does, in which case i would be greatly interested :( )
i have the physical parts manual for the car which lists the numbers, but i am not sure how nissan would advertise the superceded numbers etc.
I spend several hours looking for 70's datsun parts per week. Repco/bursons can get very basic stuff (think wheel cylinders, gasket kits etc), and that's about it. Nissan dealers have generally sucked in my experience, they seem to have a deep-seated loathing of anything more than a ten years old. I'd be combing ebay and importmonster, and join a club like the Nissan Datsun Sports Owner's Club. I can get my mitts on some second-hand 240k bits. PM me if you get really stuck, and Ill see what's in the shed for you.
I work at a nissan dealership, there are still manuals with all the parts and numbers (and crash repair catalouges) for pretty much every australian delivered datsun, including the old skylines. also can try nissan FAST, im pretty certain I saw the c210 and c110 on there last time i looked.
whether or not you can find any of the parts in stock somewhere is another thing.
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
