I spoke with Ivan from RPM. He reckons there's not that much difference in a car with a powerfc compared to a remapped std. comp. He said to me a guy had the std. comp in his r32, then changed to a power fc and the hp was the same but the mid range picked up 10-20kw.
  • Replies 92
Think he big difference is power fc gives you the ease of adjusting without having to plug an computer in, which can be handy. Also allows for monitoring of systems, AFM, injectors, knock, revs, speed, boost blah blah.
Another big plus with the power fc is that it is fully portable and can be resold alot easier than a chipped ecu.
Bottom line, is it worth it? Perhaps that is something that only the person fitting the power fc, or remapping their ecu can answer, but remapping is definately a good cost effective way of squeezing more out of your car.
If you have a chip already, makes remapping even more cost effective.
  Quote
Originally posted by Steve
Just realised I saw 9krpm at Morpowa when my car was up - thats one sweet ride you got there!
Sorry for the late introduction as I did not know who you were and can't help drooling about your car too.
Thanks for the complement.
  Quote
Matt, I got knock sensor;)
Yeah very true mate. Mind you @ 180+km/h I don't think the "eng check" light flashing would've helped me in time anyway.
Hmm, I think maybe you underestimate the usefulness. I have grone accustomed to its presence, and it so much as blinks once and I am off the gas - works really well, my paranoia helps.
It actually activates quite low on the scale to give you plenty of warning, well before its enough to cause problems.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
