  • Replies 86
Posted Images
v-spec? v-spec2? m-spec (good luck)? nur?
high kays? low kays?
modded? standard?
colour?
:EDIT:
all that seems a bit random. but theyre all things that will the price range.
you can pick up high kay vspecs through importers for a tad over 30k.
then you can find low kay mspecs, nur's, etc, for closer to if not more than 100k.
Edited by scandyflick
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902068
modded? standard?
colour?
yeah, how long is a piece of string?
give us some photos and details of ones your looking at, and we will tell ya what you need to know :D
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902080
Best if you get it privately imported. Saves you money but there is a waiting game. For a R34 GTR its well worth it. Low ks i could only guess between $45k and $55k. Check out http://www.imports101.com.au they seem alright..
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902155
modded? standard?
colour?
:EDIT:
c'mon Dave....maybe one thats been written off....or needs to be!
If you want a low km, immaculate V-Spec you'll still pay over 50K.....show me otherwise and I'll show you a piece of crap.
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902661
absolutly, there's still some cooner gtr's out there...just coz they are gtr's doesn't mean every one is immac.
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902679
strongly disagree... the guys at gt autosounds pickd theres up for bout 30k and its in show room condition...
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902699
i never said itd be any good pete :blink:
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902705
interstate 45-55 k should get you what your looking for. anything cheaper and it s a case if buyer be EXTREMELY WARE
dont rush into anythin either shop around because the price of r34gtr's is stilll not completely stable... ther are alot of varied prices around and qualities varie alot
good luck with your hunt
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902717
that's incorrect, I spoke to George Spartalis yesterday and looked at the car. its done double the kms that mine had done and mine's silver which is the colour thats most in demand from Japan and he paid $47K.
Here it is:
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902898
unfortunately they're not immaculate, way too many kms & still need tyres for compliancing.
If they tell you it "runs well" only, it's probably been on the track a few times
https://www.sau.com.au/forums/topic/221342-bnr34-gtr/#findComment-3902907
    • Hi, We've all posted some thread, or know of some other person's thread, that contains information that we want to send people who are asking question to. But if we don't have a link readily available, have to go do a search for the thread before being able to do so. So, it occurred to me that we could possibly utilise the auto-text-replace function that fixes some of my swear words to perhaps auto replace some special keywords with text that also has a link to the thread. A specific example. The thread that I did with the improved R32 GTR wiring diagram scans. If the phrase "R32 GTR wiring diagram" could be auto replaced with "R32 GTR wiring diagram" then all I (or @Duncan, or any of the others that refer to the thread) need to do is remember that that's the keyword (or phrase in this case). OK, it would be better if this keyphrase wasn't that long, but it does need to be specific enough that it doesn't get triggered automatically. And obviously there are threads on turbo topics, or suspension topics that we could treat similarly. Alternatively (and/or additionally), I've been thinking about trying to build a library of the real expert content that is trapped in the bowels of the 25odd years of this site. Things like some of SydneyKid's content. There are threads that he started that should be more easily found, and he has individual posts, or series of posts, in other people's threads, containing very good information. Some of us know that it is there, but....just have no memory of exactly where/when/how we saw it. If we had some sort of library thread, we could put posts in there containing links to things we've found, suggestions for how to categorise it, then a mod or other appointed thread maintainer can copy the link and any key text up into the first post in the library thread. There are probably many other ways to get it done. Some sort of wiki is probably the best way.   Thoughts?
    • But, probably that happened to the last person too, which is why the RTV was there.....if you aren't putting a new gasket in you will need to seal the old gasket back to the metal surface with something, the gaskets will generally only work properly for a single use as they set/harden in that shape
    • What is with the horrible blue and white bit in the centre of the wheels, didn't that come off with some scrubbing?
    • Not sure how broadly you define Northside  but Castle Hill Exhaust are still around and could sort it.
    • I haven't done this as I still use the factory cluster, but I do know the circuits for the flash vs on for hi beam are separate which is likely the issue. The ON runs full power through the switch and the flash uses the relay in the engine bay. I'd hit the wiring diagram per GTSBoy's suggestion
