Make: Nissan
Model: S15 200SX (ADM, Spec S)
Milage: 80,000km
Transmission: Manual
Colour: Pewter
RWC supplied? N/A---> no such thing as an RWC in SA, it's rego'd or it's not here
Currently registered? Yes
Price: $35,000neg
Contact: PM or 0401 030 630
Comments: I have built this car up myself, originally had exhaust and FMIC, about the only work I didn't do was the cams and clutch/gearbox (work done by Tilbrook's instead). Serviced every 5000km with Motul 8100, books/records available. Just clocked over 80,000km and will be going in for a full service this week.
Car has been thought out and modified in all areas, has been built not to attract too much attention, never been defected or hassled by police, currently runs on 1.0Bar daily (though was tuned on 1.1Bar ~240rwkw), has been to Mallala once the rest of the time it's my daily driver, average temps on the street are 80-82deg water and 80-85deg oil with the present cooling setup, peak temps never exceeded 88deg water and 94deg oil and the car is never pushed hard on hot days......overall a very complete car as is be it street or track or both
Modifications:
ENGINE
Trust/Greddy T518Z turbo 8cm
HKS step 1 cams
Tomei rocker arm stoppers
Apexi Power FC
Greddy Profec B II
FMIC (hybrid style but custom piping)
Standard cast iron manifold
Tomei stainless dump pipe
3†front pipe and high flow cat
X-force cat back (customised and cut to sit closer to body of car)
Apexi Pod Filter
Z32 AFM
Custom SS intake pipe
Custom CAI and heat shield/partion
Trust/Greddy Type S BOV
Signal catch can
Nismo engine mounts
DRIVELINE
RB25DET g'box with custom SR bellhousing (fitted with billet selectors for 3rd & 4th ~$900 each)
Nismo g'box mount
Veilside gear knob and custom shifter
New "Rebuildable" Ford yoke/uni joint for tailshaft
OS Giken TS2CD twin plate clutch
Braided clutch line ADR approved
Nismo 2-way diff with 4.36 ratio
Alloy cradle bushes
BRAKES--->installed about a month ago
R33 front/rear calipers...freshly powder coated
(calipers rebuilt with new seals/dust covers/channel o-rings)
New RDA slotted rotors front and rear
New Lucas TRW pads front and rear
Motul Dot 5.1 brake fluid (higher temp and specifically designed for ABS vehicles)
Drum handbrake from R33 connected
RIMS/SUSPENSION
17" Rays Volk TE37's in bronze (8.5" +30 and 9" +40)
Toyo T1R's 235/45 and 255/40 tyres
Rays Duralumin lock nuts
Tein Super Drift coilovers with 8/6 springs (can lower another 3" front and rear without affecting preload, spare springs for 10/8 included)
Tein adjustable front camber tops
Tein EDFC unit (in car electronic damping control adjustment for coilovers)
Kazama adjustable castor rods
D-Project adjustable rear camber arms
D-Project adjustable rear toe arms
Cusco front strut brace
Cusco rear strut brace (below parcel shelf type)
FUEL SYSTEM
Nismo fuel pump
Nismo 740cc/min injectors
COOLING SYSTEM
S14 thick single core rad
R34 clutch fan
Trust/Grex oil cooler kit with thermo and filter relocation
(full braided lines with Earl's fittings)
INTERIOR
Trust/Greddy electronic warning gauges x3 (matching silver face/amber light)
-boost
-oil pressure
-oil temp
Trust/Greddy dual guage holder for A-pillar and separate Blitz guage holder
Bride Ergo 1.5 with genuine Bride driver's super low rail
Pioneer CD/MP3 player
MB Quartz front splits
Pioneer 12" sub in box
Crossfire amp
Images: note brakes were fitted after these shots
https://www.sau.com.au/forums/topic/221355-nissan-s15-2002-adm-75000km-spec-s/
may consider removing suspension and driveline and replace with original standard parts (ie remove coilovers/EDFC/all adjustable arms/clutch/2 way diff/RB25 g'box) with lowered price to help sale
......but why would you when everything has already been done
  • 3 weeks later...
realistic offers considered
For $35K I'll throw in spare RB25DET g'box (70,000km), and R33 4.08 diff + S15 Helical 3.69 (both complete).....note these are NOT for sale separately so please don't ask.
other original factory parts that can be negotiated with sale are suspension, rear camber/toe arms, castor rods, AFM, injectors, rims, CD player
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
