R33 Shell Plus More
Do you mean the entire arm or just the wiper? If just the wiper, you can get them at Autobarn or Supercheap usually.
Supercharge MF75D23L has a 650 CCA and fits a PM35 (I have one in at the moment).
This unit, right? https://www.ebay.com.au/itm/387099265984?itmmeta=01J4N51WYS8TZZQJBDHRJSXTQ0
There are two. One with "intelligent key" (proximity key) and one without. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/pm35/6844-vq35de/body/998 Doesn't look like a shared item outside of V35 Skylines which may be handy if looking for a wreck. https://www.amayama.com/en/part/nissan/d8700cg027 https://www.amayama.com/en/part/nissan/d8700ac228
G35x should be a match. Not sure if the 2008+ items will be a direct fit as they might need the front axles also - much like when upgrading to 370z rear bearings, but the 2004+ should since they are the same chassis as our PNM35 Stagea. For what it's worth, I used replacement bearings from JustJap last year which need to be pressed onto the hub.
