I have a GFB stealth BOV to fit to my R32 and was wondering if anyone knew for certain if its legal in SA since it can be changed from plumbback to vent...? Got pulled up tonight and passed but was wondering if I'd be so lucky if I had this fitted...
https://www.sau.com.au/forums/topic/221384-blow-off-valve/
it's not legal ANYWHERE!!!!
unless it's the factory item, they will find a way to defect you or cause you hassle to go get it tested etc.
unfortunately his right, but the design of the stealth BOV is so that its harder for cops to defect you.........well its supposed to anyway.
you can argue that its plumbed back......alot of cops will think its okai but ull pump into the odd few who will put up a fight.
https://www.sau.com.au/forums/topic/221384-blow-off-valve/#findComment-3903309
Like the other fellas have said... BOV's are 100% illegal unless stock from the factory... but you will notice that most stock turbo cars will have recirculated or plumb back BOV's... I just couldn't resis the Ssshhhtttt sound so I took a chance... got defected 3 times for it... but I had to push on as the let of sound is too addictive... up to you...
https://www.sau.com.au/forums/topic/221384-blow-off-valve/#findComment-3905477
Fartyboy73 i think you've been made fun of more than helped :thumbsup:
I say stock BOV FTW, and plumb back FTW. Otherwise you need to consider how you'll hide an ATMO. I reckon it's pointless, as is the retarded PPSSSSHHHHTTt LOOOOkattT meemeeeeee!!11!!!1!
https://www.sau.com.au/forums/topic/221384-blow-off-valve/#findComment-3907281
the stealth GFB bov is a 2 way bov. you can turn the thing to be either full plumb back (which is legal) or full atmo.
problem is if a popo looks at the bov and sees a venting trumpet. theres not much u can do to convince him its plumbed back.
https://www.sau.com.au/forums/topic/221384-blow-off-valve/#findComment-3907315
  • 4 months later...
just stay standard unless your putting allot more psi into the thing..... they rated for 16psi of memory, anyway its somewhere around that mark... My r33 has a nice sneezing sound (CHHHHHOOOOOOO), I like it, also when i'm driving near a cop just let go of the accelerator slowly half a second before you push the clutch, no sound from the bov = less cop attention (or in the GTA or scarface game world less heat)
https://www.sau.com.au/forums/topic/221384-blow-off-valve/#findComment-4170902
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
