GTS-T are 16x6.5" +40 offset and are Cast wheels
GTR are 16x8" +30 offset and are Forged wheels
Both designs are the same just the gtr are stronger being forged and stick out further becuase they are wider and have a lower +offset.
Cast and forged are the way wheels are made. I think cast are just pored into a mold and forged are machined out of a piece of steel. (maybe someone can confirm)being forged is much more expensive and creates a stonger wheel.
Edited by Brokenz
forged are 'cast' under pressure which improves grain alignment and therefore strength. Therefore you need less material for the same overall strength, so it is lighter... forging is different to machined
"billet" is generally used to describe machined wheel pieces, eg 3 piece rim centres may be from billet, ie start with a block of aluminium, use mills to machine to the desired shape.
We need to swap jobs for a while. LOL so i can get some office time and gawk at beauties in suits and you can work in a dirty engineering field :ermm:
Forged is typicall from a machined billet which is then pressed whilst at an elevated temperature to the required shape. Typically more machining follows. So not really similar to casting. Though there are several forms of casting with some better then others.
ahh ok thanks for that. Makes perfect sense. Now while you guys are here :) i'll get you to answer another question for me please :]
16x6.5 ... whats the widest tyre i can get on them without being too dangerous :D 215, 225? or 205 is the widest i can go?
Thanks guys, and thank you optus for providing such an awesome shaped 28.8 bandwidth.
what u are talking about is actually called pressure casting, not forging. forging is exactly that, pressing and forging solid billet alloy. The alloy is often heated up to soften it, and even in some instances to almost a molten form (Semi-Solid Forging patented by SSR) to make it easier to forge. Casting under high pressure can create good results, but it still isnt forging, low pressure casting is used in most cases, especially OE, so id imagine it is what is used for the GTS-t wheels. Obviously then there is gravity casting, u really want to stay away from this at all costs lol. Generally forging is only used for the disk, the rim is usually "flow formed" or "rolled" which is where they heat up the barrel(rim), spin and press the shape. and yeh, then obviously there is the CNC machining to finish it off.
ahh ok thanks for that. Makes perfect sense. Now while you guys are here :( i'll get you to answer another question for me please :]
i personally wouldnt go past a 225, 235 would be the limit tho.
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
