Hey,
I was just defected this morning on the way back home to sleep.
Police officer added "You and your mates must be really unhappy with us defecting your little drifting event, we must have got 50 cars..."
Dunno what he was talking about, but i guess hes still feeling some sort of pump from defecting a lot of imports.
I have the following:
Front mount intercooler (cut hole through side)
Blow off valve (atmostpheric)
Greddy front strut brace
Boost controller
black steel intake pipe.
Turbo (hiflow).
What would I need to do to change them?
Any input?
https://www.sau.com.au/forums/topic/221391-defected/
  • Replies 97
In response to his comment I would of said no i am on my way home from work.
You will need to bugger off ya blow off valve.
Strut brace (prob wouldnt get told off for it but still its an A/M item so bugger that off.
Boost COntroller.
High Flowed turbo will be no issues if it's just the RB25 turbo highflowed. As there is nothing changed on the outside of the turbo.
With the FMIC have you cut up your reo bar at all? if so that may fail you. And the hole on the side just get some vac hose slice it down the middle and put that around the hole you cut for your pipe.
And I would take the induction pipe off aswell just incase.
And anything else you have done to your car
Hey,
Boost controller
Turbo (hiflow).
Any input?
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3902920
kralster, ghosting this forum.
I said to the guy im on my way home from work, i had my work gear on, reflective jacket and all, and he was a c*nt really but yeah...
I also have the car lowered, and I have 18x9 and 18x8 rims on the car. on TOP of that, i lost my f**king wheel lock nut key and I have to get a new one from Tyrepower Adelaide.
Apart from that, the exhaust aswell, 5Zigen system.
Its gonna be a long 3 weeks i reckon.
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3902930
the fmic should be fine unless you've cut the reo like someone else has said! and i've also done the hose thing! i got through so there's no reason why you shouldn't with that
with the bov if you still have the standard one get it back on! i put mine on my intercooler piping and they've so far been cool with it!
i never knew strut braces were illegal! if so then the po po have been letting it pass
don't know about the boost cont! (if it's a manual or electronic one) but the intake i've got stock air box and stuff if that'll help!
as for the turbo! i think my workshop still has one of my standard r33 turbo's!
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3903080
Hey,
he would have been talking about the defect station they had set up out the front of mallala last weekend.
just goes to show they are more intesested in working AGAINST us rather than with us to make the streets a safer place.
having a station set up out the front of an event like that is like taking candy froma baby for them,
then bragging about it....just lame :woot:
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3903083
why did you get pulled over pauly? were you driving like a ratbag?
you'll probably need to do everything that Brenton mentioned in his above post.
i dont reckon you need worry about the rims, they'll just check that your tyres have a decent amount of tread.
And even your exhaust... if you can cheekily shut it up so its under 90dB at around 3500rpm, they should pass it.
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3903087
True. When they target events designed to keep the heat off the street, then they bring the heat to you, thats lame and bloody weak of them. Next, people are going to avoid these 'legal' off street events and take it onto the streets, because the cops will be targetting events such as this.
On the other side of the coin, we do have alot of import car drivers to blame for such attention. Obviously the police are doing anythying, right or wrong, to get their message across.
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3903164
then bragging about it....just lame :D
yeah and so many cars were getting done that day too including myself.
might see you at regency pauly :)
Edited by Import S13
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3903398
ah yeah was on my way to tafe
dont care where im driving at the moment cause they cant defect me again (unless i go to regency and get double defected :D)
I thought u got fines and stuff if the police see u with a defect sticker on the front? Seen a car the other day with 2. Sucks to hear that pauly, after u got ur licence back and that.
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3903620
nah ive got a clearence from the sturt police station to drive the car while on defect. theres a small part on the back of the defect paper at the bottom that will grant you clearence to drive till your regency date. ive got mine under the defect sticker.
also Tangles, when i was getting defected, they pulled in a creamy stagea and defected him too and that looked pretty stock :D
https://www.sau.com.au/forums/topic/221391-defected/#findComment-3903654
Guest
