Hey all,
As title says its a dec 95 model Black manual, has done 83,000km's (imported with 73.500km's!! Basically driven to and from work only, bout 35km's a day) I am the first owner in aus. I have spent a lot of money on it since i got my liscence in feb, basically all mod's except for the air filter were put on by me since then. Oil changes every 3,000km's with Penzoil Race Synthetic with Penazene addative. Mods include:
-17*8" Gradu racing rims
-Custom ATP T03/4 turbo
-Custom AVO bar and plate front mounted intercooler with polished mandrel bent alloy piping, no welded joins (cooler polished aswell) and Hose Techniques blue silicon joins
-3" dump pipe off turbo to cat into a genuine 3" Fujitsubo LegalisR exhaust
-K&N M's high power air filter
-HKS turbo timer
-AUtometer ultra-lite pro comp gauges
-Custom alloy catch can all polished with braided fittings
-Razo race gear knob and Razo race pedals
-Custom dash switch panel covered in pearl white vinyl.
-Odyssey dry cell battery
-Nismo belt pads on all belts, and Nismo hand brake pad
-Pioneer head unit, front splits, 6*9's running off 600wAmp, boot wired ready for big sub set up, previously had a huge system in it, and have left all brand new cabling ready for new subs/amps. Also has false floor fitted with all panels and wheel well filled with dacron to kill dead sound and improve sound quality.
Also had the timing belt and all axilery belts changed, front urethane castor rod bushes and a new o2 sensor fitted so she is absolutely puuuuuuuuuurring!!. Also now has 12 months of reg to... so can't complain at all peoples!!
http://www.angelfire.com/co3/thegrub1/inde...dexskypics.html
I am askin $20,500 with RWC and 12 months reg!! BARGAIN!!If interested, and can meet in Melbourne to view. I am looking to get rid of it asap, she is one of the best round, trust me!!
http://octane.nt4.com/firesport/ind...on=show&id=2730
https://www.sau.com.au/forums/topic/22141-modded-95-m-spec-r33/
  • 3 weeks later...
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
