http://www.finalgear.com/ - main story.
The Australian version of Top Gear now has it’s hosts — Motorsport commentator Charlie Cox, cartoonist Warren Brown and driving instructor Steve Pizzati.
Currently a motorsport commentator for the BBC, Cox, 47, is known for his classic one-liners.
He worked in radio in Sydney in the 1980s before moving to the UK where he won several motor racing titles in the 1990s and was involved in a near life-ending crash in 1995.
Brown, in his mid-40s, is best known for his work as a cartoonist and motoring columnist for The Daily Telegraph, but also has a passion for historic cars.
The third host, Steve Pizzati, is the youngest of the bunch, in his mid 30s.
He is an advanced driving instructor, freelance motoring journalist and a race driver for Porsche Australia.
Sydney Morning Herald motoring editor Josh Dowling will act as the motor industry consultant.
they will always say it is not as good as the original.
like big brother, America stole it and it failed miserably (i am pretty sure it was big brother)
thou to be totally honest big brother in Australia sucks as well. :D
Pretty sure it sucks everywhere. The USA had it before we did (like everything) but it's a worldwide franchise.
Sorry for the re-post. I only checked Vic section and checked first 2 pages, so it musta been elsewhere.
The issue I see is that as Australia is so far from Europe, access to all the cars would be trickier.
James would have been good on it. He should know a thing a too by now about the exotics.
So they want to take this british show and make it australian, so of course the first thing they do is get a brit host who has no relevance or is known by any car audience in australia and then they add a cartoonist with a passion for classic cars, top gear is not about classic cars for the most part its about exotics and performance cars, the third guy seems like he has the credentials to do this job though.
cant see it lasting long.
I don't think it will be that bad. Sure, they won't match up to Clarkson, Captain Slow & Hamster but that would be a huge ask for anyone.
I like that they have chosen some proper enthusiasts and drivers, rather than some shit TV personality like Glen Ridge or Jamie Durie.
As long as they review a good mix of mainstream and exotic cars with a sense of humour, I for one will be happy for a second (but different) dose of Top Gear every week!
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
