Hi guys,
Finally got the GTR, now come the barage of questions...
This will probably be the first of many in the coming months.
I have a gear stick that rattles, it does it the worst in 3rd gear when the stick is left un touched. If I move it up about 1-2mm with my finger it stops. It does it in most gears but can be stopped by moving the stick that little bit to the "sweet" spot.
Is this normal? I am unsure if it is a short shifter or not as I have not driven another R32 GTR. How can I tell if it's a short shifter or not?
Well I think that's it, short and sweet.
Thanks in advance
Jarrod
https://www.sau.com.au/forums/topic/221432-shifter-rattle/
there is a small nylon bush at the bottom of the shifter, yours might be worn. they are a match to other local ones including r31 skyline ad 21 navara so your local nissan should stock them if they are the problem
https://www.sau.com.au/forums/topic/221432-shifter-rattle/#findComment-3910511
the bush is dead easy once you have the shifter out. getting the shifter out can be tricky - console off, rubber boot off then you will need circlip pliers to remove the circlip - easy to loose be careful. once youve done all that you are ready to go
https://www.sau.com.au/forums/topic/221432-shifter-rattle/#findComment-3912247
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
