  • Replies 56
I have always wondered - how strictly is this enforced?
i have let fireworks off after the weekend and nothing happenned to me..
last year i got a massive amount of fireworks from adam and eve.. we let fireworks off on the saturday, sunday and the monday nights and i still have some left.. i think it was 6 bags for around $100 or something like that.
you can also get fireworks from most of the asian supermarkets in dickson but they charge heaps compared to adam and eve
https://www.sau.com.au/forums/topic/221454-fireworks/#findComment-3906049
oh i love them, you will have to have a ACT license though, you will see shops pop up every where over the long weekend i love fireworks brings out the child in me :P
The boys are right. There is many places up that way to get them. You can also go to Exhibition park near mitchell. There is a few shops there that will open up soon. You need to have proof of ACT residency in order to get the permit and purchase the fireworks unless your well connected. Just change ur license over at the Gov shopfront and ur set
Edited by naughtyruski
https://www.sau.com.au/forums/topic/221454-fireworks/#findComment-3908102
haha, all the cool kids buy their fireworks out of the back of some guys car. Dodgiest thing i have ever done....
Call the number of a guy I got from a friend, change of location twice before getting in his car to drive to a 'safe' location. Boot opens... Gunpowder heaven. The guy had rockets for craps sake, thats the proper gauge for firework selling, wow your prospective customer with 80cm tall rockets in your boot. That was a fun weekend, only one of our group got arrested haha
but yea, long weekend only. I'd stock up this year, they are getting more and more strict as the years go on, apparently it is illegal for the stores to advertise fireworks this year
https://www.sau.com.au/forums/topic/221454-fireworks/#findComment-3908234
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
