  • Replies 56
I have always wondered - how strictly is this enforced?
i have let fireworks off after the weekend and nothing happenned to me..
last year i got a massive amount of fireworks from adam and eve.. we let fireworks off on the saturday, sunday and the monday nights and i still have some left.. i think it was 6 bags for around $100 or something like that.
you can also get fireworks from most of the asian supermarkets in dickson but they charge heaps compared to adam and eve
https://www.sau.com.au/forums/topic/221454-fireworks/#findComment-3906049
oh i love them, you will have to have a ACT license though, you will see shops pop up every where over the long weekend i love fireworks brings out the child in me :P
The boys are right. There is many places up that way to get them. You can also go to Exhibition park near mitchell. There is a few shops there that will open up soon. You need to have proof of ACT residency in order to get the permit and purchase the fireworks unless your well connected. Just change ur license over at the Gov shopfront and ur set
Edited by naughtyruski
https://www.sau.com.au/forums/topic/221454-fireworks/#findComment-3908102
haha, all the cool kids buy their fireworks out of the back of some guys car. Dodgiest thing i have ever done....
Call the number of a guy I got from a friend, change of location twice before getting in his car to drive to a 'safe' location. Boot opens... Gunpowder heaven. The guy had rockets for craps sake, thats the proper gauge for firework selling, wow your prospective customer with 80cm tall rockets in your boot. That was a fun weekend, only one of our group got arrested haha
but yea, long weekend only. I'd stock up this year, they are getting more and more strict as the years go on, apparently it is illegal for the stores to advertise fireworks this year
https://www.sau.com.au/forums/topic/221454-fireworks/#findComment-3908234
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
