Hey guys,
I talked to my friend (Joe) and he is actually running his own fireworks store this weekend in Gungahlin under the waves carwash and on wooley st in Dickson. Tell him Steve with the white 33 sent you and he should work something out for you :D.
Edited by R3sp3ct
  • Replies 56
Hey guys I'm from QLD but am coming down to see family for the long weekend... I wan2 buy some fireworks but being from QLD don't have ID... is it possible to meet up with someone so they can get me fireworks.... PM me and of course I'm happy to through some extra cash your way
just by asking at some of the stores we wound up with some fairly amazing Mortar fireworks (not saying which one, just ask at the smaller stores if they have any bigger ones). $60 for 10 'rounds', fired 2 off tonight and they are insanely loud.
Also don't go to Adam and Eve, theres a store in the same carpark as the Higgins shops that sells the same packs (pink, blue, orange etc.) for $20-30 cheaper. 50-60% off my arse...
Locked all my cats and dogs in the shed before heading out.
About 5 or 6 years ago 2 of my dogs ran away on fire works nights from our old house in Rivett, 1 of them was found a day later, the other disappeared. 10 months later we got him back after the people who found him decided to get him checked at a vet before moving interstate, they found his microchip and we got our dog back.
Hopefully no one was doing any stupid crap with fireworks, apparently this year is the trial year. If too many problems arise fireworks will be illegal in Canberra like all the other states.
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
