Hey guys,
As some of you may know I'm in the market for a new car.. the thing is I need to get a N/A (new laws).. and don't want another gutless N/A skyline really..
I'm looking for:
-Manual
-Must have some guts
-Must handle well (want to get into some track days etc.)
-Don't care if its a shitbox
-Roadworthy
Been looking at a couple of slightly worked 31's so far, really don't know what to get.
Forgot to mention, I have $1 - 10,000 to spend.
Any help would be great.
Thanks, leigh
https://www.sau.com.au/forums/topic/221467-what-car-should-i-get/
  • Replies 55
Posted Images
yeh i was thinking about the xr6's but there a bit pricey (for the half decent ones) + cant realy handle
as for the pulsar i was thinking RWD. nothing wrong with the n/a sr20's on a light car tho maybe a n/a silvia.. but so rare..
trust me, save urself fines and hassles, get a 4x4, put big tyres on it and intimadat the shit out of people on the road...
less attention from cops and u can have so much fun... i went from a 32gtst with about 150 to 160rwkw and i love my new 4x4..
tax time she is getting a rb30 and september a slap on turbo for some dose noise...
TRUST ME, 4x4 is the way to go.....
Do you care about fuel economy? If yes then like a SSS pulsar with SR20. If no like an XR6 falcon with some head work.
*Edit* Ignore the falcon, you want a car that will handle well.
This man had a good suggestion. An N14/N15 SSS is pretty quick, handles well, has reasonable carry space, is easy to park, is fairly good on fuel and looks good. Only thing to watch out for is the insurance price for a young driver :O
They are quicker than an SR20DE S13.
Edited by llama_au
This man had a good suggestion. An N14/N15 SSS is pretty quick, handles well, has reasonable carry space, is easy to park, is fairly good on fuel and looks good. Only thing to watch out for is the insurance price for a young driver :rofl:
insurance is gona be more cause it went through insurance after the accident
either way its gona be high sorry to say :O
duno if you could afford one but maybe a N/A Aristo?
they look heaps good and are powerful and luxerious(sp?)
MR2 is a good idea. It'll handle well and they aren't common which is cool.
If I was on the restrictions like P platers are now I would probably go for an N14 SSS. I never liked them till i went in a mates. They really go hard.
They're cheap too. Throw in some cams, headwork, swaybars and suspension and they are a cool little unit.
If SSS is too much for insurance some of the Pulsar Q's had the SR but missed out on the Viscous front LSD. FWD can be fun but you've gotta know how to drive them. I wouldn't have a clue since I've never had one.
Minus the turbo conversion :ermm:
No Australian-delivered N14 (Aus-built and Jap-built) or N15 had VLSD, they're all open diff. Overseas various models (including SR18DE, SR20DE, SR16VE & SR20VE-powered cars) came with VLSD boxes, they all fit an SR20DE-powered N14 or N15. If you want one make sure you get matching driveshafts or you're screwed. They're shorter ratio and good for extracting some extra acceleration. The car will rev higher at freeway speed, only big disadvantage. Oh, and the VLSD is entirely useless with any decent power.
Get a Nismo mechanical LSD. There's nothing better :ermm: And for reference the N14 does handle better than the N15, but the N15 is otherwise the more reliable, newer option. The N14 has IRS whereas the N15 has a rear beam axle.
I wanted an AE86 back when I was looking for p-plater friendly cars, unfortunately the Takumi tax on them makes them too expensive for what they are. Pulsar SSS would be good. But depends on what your looking for ie. if you want a project car or a regular reliable daily driver.
I have a NA Z32, not a common choice for p-platers as they can be pretty expensive to maintain if you get a bad one. It handles well, it's definately not gutless... makes around 120rwkw stock and has heaps of torque.
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
