  • 1 year later...
  Chris Rogers said:
no probs. give me a bit and I'll work it out for you.
ac controller is the worst bit.
also what year?
Hi Chris, my CD player got an err f0, i want to do a radio conversion for it. have you got all te parts instock? what is the price for that?
my car is 2003 model, premium pack with BOSE, dual zone climate control and im in Sydney. thx.
Geoff0110,
not cheap. if you are expecting a couple hundred bucks think again.
give me a call. (see sig) I'm doing a run to sydney early feb and if you want bits I can have them with me.
thx guys, i know it is easy to find Center Console Dash Finisher Trim and A.C. Control Unit on ebay or from G35driver, but how about the head unit for bose system? any suggestion?
also, another question is how to take off the knob for manual shift? I found some threads that show you step by step, but they are all for auto one.
I could talk till I'm blue in the face....
I SELL THIS SH!T....
bose is not an issue I have a plug in patch for it, makes the entire system work as it should without volume issues. want one ask.
manual car is the same as auto. knob unscrews.
Hi Chris, thx for your reply. Can you please pm me the price for the whole kit, including ac control, console, a head and any other accessories requied. basicly i want to keep using the OEM bose amplifier if possible, and also i know there are many heads in the market with lots of functions from $350 to $2000+, but i just want a 2din one with basic functions as cd, mp3, and aux input. I did some research on online and it is too complicated to order parts from overseas and from different suppliers. so.....look forward to your reply.
  Chris Rogers said:
Geoff0110,
my friend who also bought the 2 din kit want to find someone for installation in sydney,
do you know where offers a nice installation service ?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
