Bodykit - Spray / Fitting / Modifying Quote ???
Well finaly i've saved up enough to get my bodykit installed but I have afew questions that maybe some of you can help answer.
Im getting all the work done at a place local to me called 'Kingswood Kustom'. The owner there (Mark) has done mechanical work on my previous 2 cars over the last 4 years. Its pretty much a 1 owner + 1 trainee type business with nothing really flashy or fancy. For all mechanical work i've previously had done (many $1000's) the job has always been done at a decent price, sure sometimes it'll take an extra hour or I might have to stand around for 10mins until he can serve me (stuck under a car or something) but I guess in the end the job is done. He sorta has the attitude of 'if i do it spot on the first time i wont see u again' type guy.
What I plan on getting done is:
* Nismo 400R Sideskirts painted and fitted
* Nismo 400R Rear bar + side pods painted and fitted
* GTR Rear Wing painted and fitted (with carbon blade)
= $1000
First of all does that seem a reasonable price???
I haven't been to any other body shops or rung anyone else etc (wouldn't have a clue where I could even get it done anywhere else). So the quote he has given me im just sorta "yeah ok no worries" type attitude.
Now while he has all the paint mixed and ready to go (he said around ~$135/L to buy/mix so he doesnt want to waste any) I was thinking of getting some work done to my standard M-Spec front bar.
Now for an extra $500 (Not forgetting that an aftermarket front bar is about $650 fitted) I can get done:
* Cold air box (bought from UAS 7mths ago) fitted with ducting down to the corner of the front bar
* Center bracket where the number plate is attached completely cut out and removed to allow better airflow to the FMIC
* Mesh the bottom part of the front bar to make it look neat n tidy
* FMIC aligned to the center of the bar (its currently about 1 inch off center to the left up close
* Front bar re-sprayed
The questions I have are:
* Can anyone recommend local places (Western Sydney) where I can go for a quote or further ideas ?
* Does the first quote seem reasonable ?
* Does the second quote seem reasonable ?
* Will the small corner gap in my front bar allow sufficient are into my pod box partition ?
* Should I get mesh put infront of the FMIC to cover it up (stop stones loose dogs etc damaging the fmic) or will this effect airflow -too- much?
Thats all for now....
PS. If your thinking about putting a bodykit on your car dont bother. For the same price as the bodykit cost me to buy/paint/fit I coulda had a set of 17" tyres n mags + a PowerFC. It will be all worth it in the end though I think.
Catch up??? What's that biatch? I already have 17's and a PFC...
doesnt matter if you make more power than me....hell, it wasn't even on the same friggin dyn.....oh wait......um...never mind....
ROFL!!!!!
I got more stickers so I am cooler than you....!!!
/me runs and hides behind something.....ANYTHING!!!
what is the contact for these places that make kits .. i still haven't found anyone who can supply me with a 400r rear bar yet besides unique autosports ... dammit i want that one but its a bit pricey ... jetspeed i've heard too many bad things about them so i don't want to get one from them ... where are u getting urs from??
Leaving the front bar as the standard M-Spec bar.
Fitting and painted is an extra $1000 ontop of that $1800.
Although instead of getting this done next week i'm getting my brakes fixed + upgraded instead (prefer safety over looks).
Front pads
Rear Pads
Caliper overhaul front n back
Calipers, rotors, suspension painted black
Front Braided lines
~$1300
So the bodykit will be put on in around 2-3mths.
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
