Basically i've installed a single t04z on my rb26 and want to run a single 90mm Q45 afm along with my power FC. Have looked at some tutorials on here, but there mainly for Z32's.
I've had a look at both the wires running to either afm.
The factory rb26 afm has 4 wires, opposed to the q45 which has only 3.
The rb26 afm has 2 wires separately and 2 wires that merge into a single casing (so it looks like 3 wires, but really 4).
I've worked out what the 3 wires on the q45 plug are from (paul33 webpage) but unsure of which wires they connect to on the rb26 loom.
So i was wondering if anyone knows how its done. or which wires go to where? and whats the extra wire for?
I'm just going to parallel the 2 sets of rb26 afm's wires together and run it into one Q45 afm.
Rb26 plug on left with 4 wires and q45 on right with 3 wires.
Rb26 plug
Q45 plug.
Any help would be greatly appreciated.
Thanks
https://www.sau.com.au/forums/topic/221481-need-help-wiring-up-my-q45-afm/
the Q45 afm is a bit of a hit and miss lately, apexi only document it to around 260rwkw
the z32 is rated well over 300rwkw, we've seen 360rwkw with a Z32
The Q45 has 3 pins (its on my site paulr33.skylinesaustralia.com) its basically power, ground and signal - the site tells you which which
then you just need to work out whats on the rb26 plugs, meggalla's site should have this for you - search for it on google
<Reference>
80m RB25 airflow meter can measure up to approx. 300ps (221kW)
80mm VG30 airflow meter can measure up to approx. 500ps (368kW)
90mm VH41 airflow meter can measure up to approx. 400ps (294kW)
i think there different models of the humble Q45
anyway try it and let us know how u go
would be good to see some high power out of it
if you do - can you please post up the serial # of the unit and a photo of the label
wil help other guys yield out incorrect Q45 models
Will do.
I've looked on Magalla's site, and theres no info on what wires are what on the rb26 afm, only on rb25's.
Just need to know what the 2 wires joined together are? are they just ground wires? while the other 2 being power and signal.
Okay i think i found what wires go to what on the rb26 afm's as it seems they are the same as rb20/25 afm's.
So was just wondering as the 26 afm has 2 ground wires (12v ground and a signal ground) can i run these 2 wires together and join it up to the one ground wire on the q45 AFM?.
be interresting to see results on this. there is a guy on here, a trader selling these now, saying they are good for over 300rwkw, mate of mine just finished his build, and his AFM tops out just shy of 5000rpm (RB30DET, GT35R). on only 16psi its still topping out relatively early, and although its a 30 and GT35R, i'd still say its one of the 'low power' AFMs
  • 1 year later...
Hi Paul, how confident are you in the plug wiring for the RB20DET AFM on your web site?
RB20 AFM Nissan Skyline R32
Wire A - Not Connected
Wire B - Signal
Wire C - 12v Ground
Wire D - Signal Ground
Wire E - 12v Power
Mine, a 1990 R32GTST, seems to be;
Wire B - Signal Ground = black
Wire C - 12v Ground = black
Wire D - Signal = white
Wire E - 12v Power = black with white stripe
Cheers
Gary
  • 3 years later...
I cant remember the exact details but I did speak to Gary about these Nissan V8 MAFS and he reckons the difference is the element inside them .
If I have it right some of these elements can "interchange" and thats the primary difference between say an 80mm R33 GTST MAF and the 80mm Z32 TT one . He thinks that its a similar situation with the 90mm V8 ones and obviously the one to have is the 90mm body with the insert/element that the Z32TT one has .
With care it may be possible to transfer the guts to get the right combination but its always preferable to have the right one brand new where possible .
A .
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
    • 100% agree. Best bet on an RB will be NEO, but even it will be a long way off. Emissions is one of the big reasons car manufacturers went to DBW and constantly variable cams. When cruising, open the throttle right up, but reduce dynamic compression so low, that it's basically an unrestricted air pump moving very little air.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
