HI ALL
was going to paint my rocker covers and coilpack covers and the cam cover
just wondering if i need to use a heat proof paint for the plastic cam and coilpack covers or will just normal auto paint do the trick as i want to do it the same colour i have on my dash.. i know i need the heat proof paint for the rocker covers.. just wasn't sure about the plastic..
has anyone done these in auto paint?, any issues?
Any help will be greatly appreciated
Cheers
https://www.sau.com.au/forums/topic/221513-painting-the-coilpack-cover/
Ive heard its fine, but I wouldnt trust it for longevity.. Id say spray heatproof down, spray your colour ontop (sand smooth first tho) and then clear coat with heatproof then id doubt you would have an issue.
For the plastic might as well do the same but either way will be fine.
You can buy the heat proof paint at auto barn for like $12.
It can take up to like 650 degree C or whatever... Ppl paint exhaust mainfolds with them and it will be fine to paint you rocker cover.
Clean down the surface / sand down and apply the paint.
SAU member RSPEC painted his rocker cover and then I went and painted my Inlet Plenum. Looks nice.
Thanks decim8 i'll give it a go doing it that way sounds pretty logical having the colour in a heat proof coating, basically. :D
Cheers
He was asking if he could use normal acrylic paint/spray auto paint on rocker covers. Thats what Ill be doing.
And secondly I can mod them for you.. Dont know how much it would cost, nor what it would end up as but if your keen to be a trial im sure we can work out a super low cost. I just remembered Perspex will bend with heat to much, might have to look into some other option.
This bending is sometimes useful as I can create shapes with the perspex such as a large bubble down the middle, takes abit of effort tho
Edited by DECIM8
mate seriously, what is the thing in your engine bay that makes all the heat?
your engine..
if you want the paint to stay where it is for more than a week
spray it with heat proof primer at least
theres a picture of my engine in my for sale thread
the high temp paint isnt much more expensive
I've powder-coated mine in the GTR and couldn't be happier with the way they have turned out.. Just thought this might be an option to "painting" them. Powder -coat is good for higher temps also.
Cheers,
Adrian
Cheers,
Adrian
unfortunately the valley cover on teh RB25det's are plastic and cant be coated. :P
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
