just changed my dashboard cluster globes with leds tonight and thought I'd clean up that clear plastic cover that covers all the gauges .. Turns out the stuff can't be cleaed. Looks like someone had sprayed some sort of clearning detergen over the clear cover and didn't wipe it off and it just won't come off ... like the plastic is ruined (although it feels smooth on touch)
Anyway was wondering if there are any skyline wreckers in sydney ? This is for an R34 GTT... or if anyone has any suggestions on what to try and clean this crap off with, I'm all ears. I've tried standard detergent, alcohol etc and the stains won't budge
https://www.sau.com.au/forums/topic/221545-skyline-wreckers-in-sydney/
give it a cut and buff we used to do it all the time
cause when we had dashes out at panel shops the idiot beaters used to spill all kinds of shit on em (brake, fluid thinners, etc, etc)
quick wet sand with some 1500 and then run the buff over it and it should be fine
Ok I've tried 5 different cleaners and none seem to be able to get rid of this crap (even tried Maguires ScratchX .. which btw is a useless product - doesn't do crap on paint scratches either)
Abo Bob, is it unblemished and fits a GTT ? If so, do you want to sell it and if so how much? :thumbsup:
Forget the cleaner products they won't work.
Follow Dahtone Racing's instructions and you will find your cluster will be fine.
Wet sand with 1500 as he said.
Then polish it.
Don't bother with cleaners.
Abo Bob, is it unblemished and fits a GTT ? If so, do you want to sell it and if so how much? :P
Maguires ScratchX worked fine on my headlights to get rid of the yellow haze, though I used it to buff out scratches left behind by 2000 grit abrasive paper.
Wet sand with 1500 as he said and hand polish with Maguires's plastic polish (can't remember the name)..
ScratchX mentioned earlier will work as a plastic polish, but I believe Maguires PlasticX is what your thinking about :)
can someone just quickly explain to me what 'wet sanding' means ... just what it says ie. poor water over the plastic whilst sanding it ? What does this achieve?
You keep the item you are sanding and the paper wet. It makes the sand paper less abrasive and therefore leaves finer scratches. The idea of sanding is to start with a more abrasive paper and finishing off with a polish. In English you sand the big lumps off first and work your way down to the small ones :D
Try Brasso buy it from supermarkets. Have used it for years to clean perspex, polishes alloy wheels perfectly. Don't waste your money with the fancy named brands- try it you won't be dissapointed-its cheap.
You may need to use wet and dry if you panel is badly marked-I would use 2000 then brasso.
headlight repair kit to fix what ? the yellow headlight haze someone mentioned or the clear cluster plastic ??
To do either, esentially its doing the same thing. Making plastic go from that dirty opaque look to a clean clear look by removing layers of plastic. I have to tell you though to patient with it. Results aren't instant and the longer you take polishing them up the better they will look. :)
Damn! Why didn't I think of Brasso :) I'll have to keep that in mind for when my headlights get eventually yellowed again and I run out of ScratchX :)
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
