Always a better idea to change the oil more frequently then less so. I always change my oil and filter every 5000km. Specially considering my engine has over 100,000km on it and i'm ever increasing the power output...
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3905836
I have also heard of ppl changing at 3000km's but thats just being pedantic LOL!
Agreed.
Every 5000km seems to be the general norm on this site, and its good practice. Oil is the life blood of engines...
Way i figure it, its oils cheap, engines are expensive when they go BOOM!
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3906618
hahaha shame, my changes are every 2,000kms. But i get free oil so it's not that bad. Also i don't do many kms. so 2,000 takes me a while to rack up. :P
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3908249
5000 would be the best number to do it at.... i do it at 5000kms.
Though i cant see too much harm doing it at 7000kms
Esp if u buying high quality oil.
Why is everyone changing at such low km/s? Are these street use?
Track use?
The oil thread actually mentions that filters become more efficient after 4K kilometres or something, and therefore you should probably run your oil for 10K if your using a good quality oil, depending on your usage.
Just curious what everyone else's opinion is on the subject..?
Regards,
Gareth
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3909082
hahaha. 10 000kms for me. Its just a street car and its not like the street is the second bathurst.
Also, as mentioned before, Synthetics don't break down like minerals do.
Unless you race your car (trackdays or drags) or it pollutes its oil quickly, I can't justify doing oil and filter changes at 5K. As above ^^^, oil filters don't start working at their best till 4.5k anyway.
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3909117
anyone used redline engine oil before??
pretty exp. stuff..lol
so wat would be the life/k's out of redline oil then?
and u guys reckon that a filter doesnt start doind its job till 4,500k's????
how can this b???
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3911317
LOL!
Free oil eh! NICE!
Ah well if its free then, hell yeah! Change it when you feel like it.
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3912480
warranty says i shud change it every 10000 km (non-turbo)....
first oil change happened at 7000km.....used royal purple.....will probably change at 7000km again...
but yeah if you can afford it, then why not 5000km!? haha
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3913219
10,000km is fine.. No oil loss or excessive fuel consumption. 5,000km is better when your doing short trips every day so shops and back or if your doing long distances at high speeds for example 110km/h @ 300km distance..
Both of the above will break the sythetic down faster.. use a good filter and it helps more.
Obviously with a new engine obviously thats a different story running it in etc.
Oh yeah oil coolers reduce oil wear.. as in breakdown.. but also in colder climates can reduce its ability to lube the engine..
Saying all the above I do mine at 5k..
Edited by DECIM8
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3913357
Fully synthetic oils actually aren't as affected by the cooler temps. that is one of their great advantages.
If your car is tuned and not over fueling or used for any trackwork and your using full synthetic, 10,000km.
Many modern car makers actually recommend 20+K km servicing for their products.
https://www.sau.com.au/forums/topic/221551-oil-change/#findComment-3914552
